04-06-2013, 03:07 PM | #1 |
Drives: 2011 SLP ZL-585, 13' Silverado Join Date: Apr 2012
RotoFab coolat reservoir install
Anybody install the reservoir and move the coolant pump to the drivers rail ? Ive read some posts about it but have seen no pictures? Also with this setup is anybody reversing the coolant flow? Seems necessary.
Any help or suggestions would be Awesome! |
04-06-2013, 03:16 PM | #2 |
Drives: 2010 Camaro 1ss IOM Join Date: May 2009
I did have mine switched but we were reading higher temps so switched it back but it can be done at your own risk!
Now with that said a higher end pump bigger reservoir and better intercooler or Jannetty's ice chest should be more than enough to take care of any higher temps at your power level!
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now! |
04-07-2013, 09:49 AM | #3 |
Drives: 2010 CAMARO SS Join Date: Apr 2010
I have mine on the driver side and so is the pump ,,, roto-fab reservoir is a gallon which is 4 times more than the little reservoir magnuson gives you,,, mine runs fine there.... here is a pic
04-07-2013, 10:00 AM | #4 |
04-07-2013, 10:28 AM | #5 |
Drives: 2012 camaro 1SS/RS LS3 Join Date: Oct 2012
I'm getting ready to change mine , most the people
I talked to including Mike from Rotofab said to move the pump to drivers side , feed the pump from the tank so that would be changing the flow of the coolent to a clockwise direction .
04-07-2013, 11:12 AM | #6 |
04-07-2013, 11:55 AM | #7 | |
04-07-2013, 03:42 PM | #8 |
Mine was on the strip after back to backs nothing big but just something to keep an eye on!
