03-18-2018, 02:27 PM | #1 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
Is my gas still good??
Coming up on four months with Chevron 94 in camaro in climate controlled garage. Ethanol free. No stabilizer. This stuff should last a year right?
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
03-18-2018, 03:07 PM | #2 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
You should be good, when I was stationed in Utah, my Corvette sat for 4-5 months with a full tank with no problems.
03-18-2018, 06:10 PM | #3 |
Dumb question. If you know the car is going to be sitting for months why wouldn't you add stabilizer to the fuel?
I own a motorcycle that sits for 6 months because of winter. I always add stabilizer and have it on a battery tender during the winter.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
03-18-2018, 06:30 PM | #4 |
weSS1LEy
Because I’ve read an equal number of posts of fuel stabilizer doing more harm than good that’s why. Like it’s marketing snake oil that will gum up your fuel as opposed to a quality gasoline that will easily last a year.
03-18-2018, 07:42 PM | #5 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Well I run stabalizer in all my vehicles I store every winter. And I run it in all my out door equipment year around because of the ethenol. Have never had a problem with any gumming up.
03-18-2018, 07:56 PM | #6 |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
I've been using Stabil brand in my outdoor equipment for almost ten years. Never had a problem with them. Don't know why anyone would call it snake oil. My equipment has always started in the spring on no more than second pull. Without Stabil, I used to have to work thru the carb and pull, pull, pull.
03-18-2018, 07:59 PM | #7 | |
Spike III Build 2011 IBM 1SS/RS [COTW 6/25/12]
03-18-2018, 08:07 PM | #8 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
OP, Stabil is tested and proven. No snake oil. You should be good, but the appropriate amount of Stabil is good insurance.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
03-18-2018, 08:20 PM | #9 | |
Drives: '10 Camaro SS,Jeep Commander Hemi Join Date: Mar 2010
stabilizer
03-18-2018, 08:22 PM | #10 | |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Gasoline will not easily last a year. It depends. Primarily on how stored. In a full sealed metal can...sure a year is possible. I.E. if you buy a 5 gal metal can of VP race gas (which is gasoline)... VP will tell you = 2 years shelf life if left sealed unopened full in the can. And they fill the can to the top with zero air space. Open that same can, the octane starts going down fast. In 3 months it will not be the advertised octane. They also say do not store in plastic jugs, where the octane drops off very rapidly. What are modern day car fuel tanks - plastic. Stabil works great. I've been using it for decades. If you store a car with a plastic gas tank full of fuel for 3/4 months and no stabilizer... it will most likely start right up just fine. I'd bet though the octane has dropped off. The way I know Stabil works great is every year I put it in every small engine I have. Lawn mowers, weed whacker, snowblower, chainsaw.... And my neighbor never uses stabilizer. Every spring my stuff starts right up. And I'm constantly getting the knock on the door each Spring...hey my mower won't start. Did you use stabilizer..no. Remove carb and clean out varnish sludge. Then we get to winter, and my snowblower starts right up first or second pull. Neighbors snowblower... dead and sludged up carb. So seeing what old gas does to small engines, and how well Stabil works... I put it in my car for the winter. Slick 50 is snake oil. Stabil or Sea Foam stabilizer is good stuff. The octane will still be dropping off over time. But the stabilizer prevents gas from going bad and turning to varnish. Some people has dynod cars in the spring with stabilizer still in and the power is way down. Blaming the stabilizer. When in reality...it's the loss of octane causing the power loss. The stabilizer did just fine preventing varnish, the fuel lost tons of octane...cuz that's what unsealed gas does over time. |
03-18-2018, 08:40 PM | #11 |
Drives: 2010 Camaro SS 2SS Join Date: Jul 2017
03-18-2018, 09:13 PM | #12 |
weSS1LEy
Ok I’ll maybe use it next year. I’ve never had to store my car for more than 3-4 months though. Email from Chevron said ethanol free 94 would last a year
03-18-2018, 09:44 PM | #13 |
Drives: Miss Con Ception Join Date: Aug 2016
You don't have a carburetor to gunk up.
Spark it up and find out.
2011 1SS/RS LS3 CGM
03-18-2018, 09:53 PM | #14 |
weSS1LEy
Third winter not using stabilizer and no problem (that I know of). So how would one go about checking for the formation of varnish? Pull an injector? Pull a line? Siphon some gas?
