11-26-2017, 10:04 AM | #1 |
Drives: 2010 2SS/RS & 2007 2500HD D-Max Join Date: Dec 2014
Z/28 Rear Diff Assembly
I have a Z/28 rear that came out of a car with 3,000 miles on it. Also comes with the lines that come off the diff itself (not the whole shebang). sold. I'm not on here all the time so call or text is best way of getting ahold of me. remember, this is a helical diff, 3:91 gear, and diff cooler that you can swap right in fairly easily!
2010 Summit white SS/RS, Manzo full exhaust w/2" primaries, Roto-Fab intake, FE4 conversion, JRI Coilovers built by Ult_Performance w/hypercoils, BMR sway, BMR trailing arms, UMI toe links, solid sub-frame bushings, upper control arm bushings, radius inserts, caster locks, Taylor wires, BTR spec'd cam, tuned by ECS, various little lighting mods, ebay SLP splitter, Heritage grille, ZL1 rockers, Apex 19x11 w/RE-71r's 305/30/19, eaton tru-trac
2007 2500HD Duramax, Built trans, custom tuned beast Last edited by Wacko37; 01-03-2018 at 07:01 PM. |
11-26-2017, 12:20 PM | #2 |
Drives: Camaro Join Date: Sep 2012
Hellcats come with 2.60 rear gears
11-26-2017, 12:42 PM | #3 |
Drives: 2013 ZL1 416 Join Date: Feb 2013
because they have 8 speeds
11-26-2017, 01:20 PM | #4 |
Why was that realavent at all.....?
2007 2500HD Duramax, Built trans, custom tuned beast |
11-27-2017, 07:48 AM | #5 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Helical vs Hellcat think he read it wrong.
Orange Krush II
11-27-2017, 09:22 AM | #6 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
Bone Stock |
11-27-2017, 09:24 AM | #7 | |
would the Z28 diff bolt right in to my car without having to change anything else?
Bone Stock |
11-27-2017, 09:27 AM | #8 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
yup...
11-27-2017, 09:53 AM | #9 |
so the Z28 diff will bolt right in to an SS without modifications?
Bone Stock |
11-27-2017, 10:49 AM | #10 |
Yes sir it will!
11-27-2017, 11:19 AM | #11 |
Excellent. Thank you very much! By any chance, you wouldn't happen to know if a driveshaft from a Z28 bolts directly into an SS would you? Thanks in advance. Just want to know excatly what to buy. Already have a deal on the complete diff brand new from GM for ~$1800.00 and am thinking about buying the Z28 driveshaft as well if it'll bolt on to my stock SS 6 speed manual
Bone Stock |
11-28-2017, 07:25 AM | #12 |
Can I ask where you found that deal? I was finding $2200-$2400 for a new one.
12-04-2017, 08:52 PM | #13 |
it looks like it went up about $60 or so. But its still the cheapest i can find
https://www.gmcarpartsonline.com/p/D.../23172755.html
Bone Stock |
12-04-2017, 09:04 PM | #14 |
2SSRS@Gen5diy said that i will need the Z28 Axles. Is this accurate? Now im really confused
I have 1LE cv shafts (which i just installed this past july) and stock SS driveshaft. I would like to be able to just remove my stock SS diff with the 3.45s and install the Z28. So will my current driveshaft and cv axles fit the Z28 diff?
Bone Stock |
