10-08-2017, 05:46 PM | #1 |
Drives: 2016 2SS Join Date: Jul 2016
Anyone gone 8's on the bottle yet?
Nitrous guys, what does it take to go from 9's on motor to 8's on the bottle? Would a 250 shot done and applied properly at that level get you there? Not sure if this conversation has already happened on this site.
2016 2SS. H/C SBE 1.37 60ft, 6.36@109.49, 9.97@136+. Nuff Said.
10-08-2017, 06:43 PM | #2 |
Drives: 2016 Gen 6 SS 6spd Join Date: Jun 2017
In for results
10-08-2017, 07:00 PM | #3 |
Not saying I was going to do it. Just exploring my options. To get this P1 head unit up to a D1X is going to cost me $1,500 minimum. Then there is fuel and bla, bla, bla. I think I could do a pretty good stand alone nitrous kit for 2K. I am going to redo the pistons and what not anyway and I think I just cracked the code for tuning big cams. I kind of like the cam now. It was just a thought.
10-08-2017, 07:10 PM | #4 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
Not without another form of boost. I think redline went in the w/procharger but they were spraying also.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
10-08-2017, 07:11 PM | #5 |
You'd have to spray 250 shot or more to get there.
10-08-2017, 07:20 PM | #6 | |
A 250 shot doesn't bother me. Guy contacted me and said he was either running 9.6 or 9.4 with a 250 shot SBE/cam/bolt ons. Not sure the rest of his combo. I would do forged stock replacement pistons with a proper gap first. Then fly cut appropriately this time for my cam. I am going to rework the MSD and possibly the heads as well. I doubt I would change the cam specs any. I could run E85 still on motor and run C16 for the stand alone nitrous.
10-09-2017, 01:05 PM | #7 |
Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
10-09-2017, 01:46 PM | #8 |
Got ya, thought there were a couple more.
10-09-2017, 03:57 PM | #9 |
SNSTRSS
Pray I heard its better to run like fuels with nitrous. If you are running e85 in the tank then why not use c85 in the standalone? Or running pump gas then use c16. Can you explain your reason?
2016 Black Camaro 2SS A8 NP
10-09-2017, 04:02 PM | #10 |
The simplest answer is that I don't know much about nitrous. Never used it before and I don't do nitrous builds. Well, I build motors and what not for nitrous but don't build or run the system. I know some guys that live on the bottle though. They take over the builds from there. So I have a good base working knowledge and understand the tuning and fueling etc. I was just going to defer to them for that portion of the build. Running like fuels makes perfect sense to me. Thanks for pointing that out.
10-10-2017, 11:31 AM | #11 |
Drives: 2016 Camaro 2SS Join Date: Aug 2009
Here is a story I just did on the Fireball Camaro. It was just released today. Gives a little bit of behind the scenes into the effort made to be the first in the 8s.
http://www.lsxmag.com/tech-stories/b...rst-in-the-8s/ |
10-16-2017, 01:59 PM | #12 | |
Also, since this is my daily and I appreciate ride quality, how bad will it be driving around on end links vs. Derlin or the rubber that is in there now? I see the need for adjustability but are there any plans for a direct fit Derlin versions of the trailing arms? That also goes for a request for possibly a Derlin product for the diff mount spots over or instead of the aluminum versions? Thanks.
10-17-2017, 04:30 PM | #13 |
Drives: SS 6 speed of course Join Date: Jan 2016
I noted the new 2018 Mustang in drag mode puts the front shocks on baby soft and the rears on hard. I don't if the MRC can be controlled in the same way on the Camaro. Optimally it would be:
front: Jounce = baby soft, rebound = hard rear: Jounce = rock hard, rebound = medium MRC does not have this level of tune. I ran Hal's on my LS1, one way adjustable and very light. My Challenger suspension bushings really sucked from the factory, I swapped it all out and it made a difference. I did not go aluminum though. I thought the zl1 1le had at least aluminum on the cradle. Anyway if were me I'd look to see what the ZL1 is running as a good compromise. Delrln (self lubricating) is nice but needed for the cradle, at lest to my mind. I've also run BMR and their stuff is good... real good.
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
