09-07-2012, 10:56 PM | #1 | |
Drives: 2010 camaro ss/rs Join Date: Dec 2009
Shims on spec clutch??????????
I have a Spec P-Trim and I need to measure if I need to shim for proper clutch engagement. heres a link to a how to video
but my transmission's bell housing is sealed to the transmission. So thats not an option. any ideas or suggestion is much apreciated. Thanks!
2010 SS @gt_klr Built by Jrod Tuned by Matt Sorian LSX 434 by HKE Dragon Slayer, Callies ultra rods, Wiseco Coated Pistons, Mast 285cc LS7 Heads ProCharger F1-X Nitrous Outlet Direct Port Fore Innovations Triple Pump on E85 Alky Control Meth Injection ProEFI ECU Stainless Works 2" Headers with Corsa 3" Exhaust RPM 4l80e with Jakes Transbrake BMR Everything with 15" Conversion Zl1 Front Brakes & Carlyle Racing Rear Brake Kit Weld Wheels |
09-08-2012, 05:07 AM | #2 |
My st trim supertwin clutch needed the shim behind the slave for proper pedal throw. The P trim should be the same, as the only difference with the supertwins is the discs.
09-08-2012, 01:26 PM | #3 |
You can measure from bellhousing /motor surface to the clutch fingers, then measure from the bellhousing on the trans. to the bearing surface, like they did in the vid. and subtract those two . you just need a long straight edge to do it.
09-08-2012, 04:57 PM | #4 | |
hmmm im gonna give that a shot.
