07-02-2013, 12:11 AM | #1 |
Drives: 2010 camaro ss Join Date: Mar 2013
Cleaning carpets?
I'm thinking about getting into detailing so I'm wondering what are you guys using tho clean carpets and upholstry?
07-02-2013, 12:16 AM | #2 |
it's mind bottling..
Drives: SGM Join Date: Apr 2011
if you have a porter cable there is a few brush pads offered http://www.autopia-carcare.com/cyclo...t-brushes.html
07-02-2013, 12:25 AM | #3 |
Ok thanks. How do I dry the carpet without it being damp. Wet vac?
07-02-2013, 12:39 AM | #4 |
hmm, i havent cleaned a rug yet. maybe someone with more knowledge on the matter can chime in
07-02-2013, 09:04 AM | #5 |
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS Join Date: Oct 2011
It really depends on how soiled your carpets are and how embedded the dirt is into the nap of either carpet or seats. I always vacuum the whole car first before I start cleaning, but also keep the vacuum handy as clean because as you treat, you break up more junk that you don't want back into the seats or carpets.
There are few different techniques from brushes and carpet cleaners (Adams Upholstery & Interior cleaner is my personal Fav) to brush attachments for your PC (previously mentioned) and auto detailing steam cleaners. Master the upholstery cleaner and hand brush technique first so you get a feel for how much chemical / cleaner to use. You shouldn't be soaking it to the point of needing much more than the air and sun to dry out the interior. http://www.adamspolishes.com/t-Detai...g_Carpets.aspx Best way to dry is leave the doors open on a warm day, if you can pull it into the garage on not so warm day. The key is to get things dry inside so you're not dealing with a different problem later, however the quickest way is on a sunny day. If you're really soaking the carpets, you'll need to pull up any soaking or sopping liquid with towels, but I would hope you're not using that much liquid. Steam might take a bit longer to dry, but really cleans when combined with chemicals and a brush. (the steam loosens all the dirty and prepares it to be cleaned. ) In the end, don't over do it with product and take your time.
07-02-2013, 09:23 AM | #6 |
Banned
Drives: 2010 2SS/RS A6 & 2011 1LT/RS Join Date: Apr 2012
07-02-2013, 09:34 AM | #7 | ||
Drives: 2021 1LE Join Date: Jul 2011
The pros with high volume business use extractors.... the good ones are north of a 1000 bucks. |
07-02-2013, 09:40 AM | #8 |
Drives: 2011 VR SS/RS Join Date: Dec 2010
I use a Bissle little green hot water extractor. cheap.. works well.. its not one of those expensive extractors but it does the job.. well... but not for hi volume work.. I use it for my car and some clients part time.
07-02-2013, 09:54 AM | #9 |
07-02-2013, 11:21 AM | #10 |
Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
I put Husky liners in right after I got my car, I just hit the corners around the liner once every couple months, keeps the carpet under it looking fresh, almost new! if I did I would probably use one of those foam sprays and vacuum when the day comes.
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
