#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Dragstrip and Launching Discussion
Old 10-25-2015, 01:22 PM   #1
Merc
In The Circle
Merc's Avatar
Official 6th Gen 1/8 Mile V8 Fast List
There are plenty of threads about 1/4 mile track times, but this thread is specific to 1/8 mile track times. The Official 1/8 Mile 2016+ V8 Camaro Fast List list is divided into three classes for now.
Bone-Stock Includes completely stock car with zero performance changes. Cars must have stock exhaust, stock air intake, stock tune, stock tires, etc.
Bolt-Ons *without* Internal Engine Modifications or Power Adders. Includes cars with a modified air intakes, headers, ECU/PCM-tune, aftermarket clutch, non-stock rear gears, skinny front tires, etc.
Internal Engine Modifications and/or Power Adders Same requirements as above but for cars with Heads, Cam shaft, Nitrous, Turbo, Supercharger, etc.
The Rules:
Along with your time slip, you must post the details of your 1/8 mile pass... see the example below.
All time slips to be directly uploaded to Camaro 5 web site and not a third party photo storage service.
Example:
Car/Engine: 2SS/RS w/L99
Top Thirty Class: Bolt-Ons *without* Internal Engine Modifications
Tires used on the pass: Stock Pirelli ZR20 Summer Tires
Performance Mods (if any): CAI, LT's, DR's
R/T: .814
60': 2.01
330': 5.4490
660': 8.2898
660' MPH: 87.23mph
Name/Location of the track: Northstar Dragway Sanger, Texas
Date of pass: 9/25/2009
Weather conditions: (include Density Altitude, if known. (Optional, not required)
http://www.dragtimes.com/da-density-...calculator.php
[insert the image of your time slip here]
Be sure to post your time slips. No slip = No update to the Top Thirty list!
Slips must be posted in this forum. Referring to slips in other forums doesn't count.
Potential qualifying times require posting of an image of the entire time slip: track name. date and run information. The only exception to this requirement is for tracks that cut slip in half.(if you need help, PM me.)
Track times will not be corrected for weather or track altitude.
Any one can submit his/her times to this thread.
Only one time slip per member will be included in a given class.
If two people submit times identical to the thousands of a second, the tie-breaker goes the higher mph.
It's a top thirty list, but the entire list can be viewed by opening the link.
Modification Terms
1. Cam - Aftermarket Camshaft
2. Heads - Aftermarket Heads or Ported Factory Heads
3. CAI - Cold Air Intake
4. PTB - Ported Throttle Body
5. PI - Ported Intake
6. LT - Long Tube Headers
7. UDP- Under Drive Pully
8. Shorties - Short Length Headers
9. Exhaust - Includes any exhaust mods (muffler delete, axle back, x pipe, catbacks, etc)
10. Gears - Non Factory Gears
11. Converter - Non Factory Stall Converter
12. DRs - Street Legal Drag Racing Tires
13. Skinnies - Performance Racing Wheels
14. Slicks - Performance Racing Drag Tires (non street legal tires)
15. Tune - Non Factory Tuning
16. W/R - Weight Reduction (removing parts to decreased weight and increase performance).
Top 30 in each category.
You can also click on the link to view the entire list.
Official 6th Gen Camaro SS LT-1 1/8 V8 Mile Fast Lists:
(1) BONE STOCK 2016+ CAMARO SS LT-1 M6:
https://docs.google.com/spreadsheets...it?usp=sharing
(2) BONE STOCK 2016+ CAMARO SS LT-1 A8:
(3) 2016+ Camaro SS LT-1 V8 Bolt On's No Internal Mod's
(4) Camaro SS 2016+ LT-1 Bolt On's With Internal Mod's (Stock Displacement)
(5) Camaro SS 2016+ Power Adders Stock Displacement ( IRS Street Registered)
Old 10-25-2015, 01:42 PM   #2
joemosfet
joemosfet's Avatar
Drives: 2014 Camaro SS
What's going on here...
SOLD: 2014 Camaro Coupe 2SS/RS M6 Blue Ray Metallic, NPP, Nav
2014 Stingray Premiere Edition Coupe #142/500 Z51 3LT M7 Laguna Blue, Magride, NPP, Exposed Carbon Fiber Roof, Carbon Fiber Dash, Suede Wrapped Interior
Canceled: 2016 Camaro Coupe 1AK37 2SS Coupe, G7E Garnet Red, BRJ Adrenaline Red Trim, F55 Magnetic Ride, NPP Exhaust, CF5 Sunroof, 56R Gray Split spoke w/ machined face, RN2 LPO Illuminated Bowtie, VYW Premium Floor Mats, W2D LPO Cargo Net
joemosfet is offline   Reply With Quote
Old 10-25-2015, 02:15 PM   #3
Merc
In The Circle
Merc's Avatar
Constructing the drag strip Fast List's for the 6th Gen Camaro's similar to the Camaro 5 list's.
Old 10-25-2015, 02:37 PM   #4
joemosfet
joemosfet's Avatar
Gotcha, was a bit thrown as this is the VS forum. A bit premature, though, don'tchathink? Maybe not.
Old 10-25-2015, 02:58 PM   #5
Merc
In The Circle
Merc's Avatar
Eventually It will be stickied in the Drag Racing section once Tran creates it. Fair bit of work to get it all set up, just getting a head start on it.
Old 10-25-2015, 04:19 PM   #6
trz174
trz174's Avatar
Drives: Used to Drive Blue Camaros
Great foresight and really interesting future thread. I am excited and looking forward to baselining the 2016 SS stock 60 foot times and then trying it under the same conditions with just tire changes. Combos available are larger Goodyears, DRs and skinnys, and slicks and skinnys. All this other than the bone stock tire combo depends on whether 5th Gen wheels fit the 6th Gen. Wheels should fit, but....we'll see soon.
I think the 1/8 mile stats should be a great baseline for non-boosted 2016 Camaro performance. For boosted cars, I am looking forward to 1/4 mile stats for the turbo version whenever that appears in general press or when somebody bolts an aftermarket turbo or supercharger on a 2016 V6 or V8.
trz174 is offline   Reply With Quote
Old 12-06-2015, 10:17 AM   #7
Merc
In The Circle
Merc's Avatar
From here on time slips only please. I will be working over the next few weeks to get it up and running, but go a head and post your slips.
Old 02-01-2016, 01:11 PM   #8
CAPerformance16
CAPerformance16's Avatar
Drives: 2016 Camaro 1SS A8
2016 1SS A8 NPP
Tires used on the pass: 305/40/20 M/T
Performance Mods (if any): Drag Radials
Category submitted for: Bolt On
R/T.......... .774
60'............. 1.808
330'........... 5.181
660'........... 7.913
660’ mph... 90.79
1000'..........
1320'..........
1320’ mph…
Name of the track: Irwindale Speedway
Date of pass: Jan 14, 2016
Weather conditions: ~700 DA
To be honest, the tall DR hurt performance alittle, borrowed them from a buddy. Going back tonight with the first Circle D Billet converter, a set of cat deletes and tuned on E85 on a smaller DR. Expecting low 7's.
Car# on slip matches # on windshield in second picture.
2016 1SS A8 NPP
Tires used on the pass: 28/10.5/17 Hoosier
Performance Mods (if any): Tune E85 Convertor & Tire
R/T.......... .669
60'............. 1.573
330'........... 4.718
660'........... 7.366
660’ mph... 92.71
1000'..........
1320'..........
1320’ mph…
Date of pass: Jan 28, 2016
2016 1SS A8
7.9 @ 90.79 Stock with a tire
7.20 @ 94.71 LBO getting kicked out
Now tuned on E85, CA Performance Test pipes & Circle 4C 3800 stall shooting for low 7's next time out.
CAPerformance16 is offline   Reply With Quote
Old 03-28-2016, 12:51 PM   #9
usmcfiredog
Drives: 2016 Black 2SS
What is the average ET and MPH for a 2SS A8 stock with NPP? Only mod that I have is a catch can, which doesn't have any performance added I do believe.
Camaro 2SS
Black/Jet Black
A8, NPP, MRC, NAV
Low Gloss Black 5 Spoke
usmcfiredog is offline   Reply With Quote
Old 04-15-2016, 10:51 PM   #10
HooliganZ
HooliganZ's Avatar
Drives: 2011 2SS/RS A6
Local track had a test and tune tonight, so I decided it was time to take the car out. I'm bone stock on the stock runflats. Had a 15-20 mph headwind to contend with all night and still learning how to launch this 6 spd. The machines that print the timeslips were not working, so the ladies in the tower had to hand-write them. Probably not much to brag about, but hopefully will get the 1/8th mile M6 list started.
2016 1SS M6 NPP
Tires used on the pass: Stock GY F1 RF
Performance Mods (if any): None
Category submitted for: Bone Stock
R/T.......... .633
60'............. 2.138
330'........... 5.705
660'........... 8.526
660’ mph... 85.80
Name of the track: Wichita Raceway Park (Wichita Falls, TX)
Date of pass: Apr 15, 2016
Weather conditions: ~2027DA
HooliganZ is offline   Reply With Quote
Old 04-16-2016, 01:38 PM   #11
SGT Stretch
SGT Stretch's Avatar
Drives: 2016 Hyper Metallic Blue SS
Bone stock on stock tires (26psi)
R/T: .2893
60': 1.943
330': 5.4223
660': 8.2484
660' MPH: 87.04mph
Name/Location of the track: Big Country Raceway Abilene, Texas
Date of pass: 3/5/2016
Weather Conditions: Sunny 90 degrees 2900DA
SGT Stretch is offline   Reply With Quote
Old 04-20-2016, 11:50 AM   #12
Merc
In The Circle
Merc's Avatar
R/T: .2893
60': 1.943
330': 5.4223
660': 8.2484
660' MPH: 87.04mph
This one not so much. I need you to replace your time slip with a pic of the whole slip and circle the lane your in.
Old 04-29-2016, 01:33 PM   #13
SGT Stretch
Copy that. I'll get it when I get back from Vegas
Old 05-06-2016, 05:45 PM   #14
SGT Stretch
R/T: .2893
60': 1.943
330': 5.4223
660': 8.2484
660' MPH: 87.04mph
Better?
