03-27-2015, 05:40 PM | #1 |
Drives: 2010 silver 2SS/RS Camaro Join Date: Feb 2011
Hi flow cats or off road pipes on supercharged car.
Installing a ecs supercharger on my car ,What are the benefits of running hi flow cats or off-road pipes.i currently have kooks headers with hi flow cats.our there any added horsepower gains. I seen post where cats have melted.any advise would be great.
03-27-2015, 05:45 PM | #2 |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
I have the same exhaust setup you do. I just ordered the off road pipes today because I am in the process of boosting my car and I don't want to take the chance of them melting. I guess if you are running stock boost you should probably be ok. Probably better if other experienced guys chime in over me though.
03-27-2015, 05:52 PM | #3 |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
Much better off going catless unless you live in a state with tough emissions
03-27-2015, 05:57 PM | #4 | |
'It's an experiment'
-Don
747 RWHP 794 RWTQ
03-28-2015, 01:21 PM | #5 |
off they will go
03-28-2015, 03:11 PM | #6 |
JT Synergy RS/2SS
Drives: 2011 Camaro RS/2SS (L99) Synergy Join Date: May 2013
Guys,
For what it's worth, I just removed my Stainless Works HF cats yesterday because everyone was telling me that running 9.5 psi is asking for trouble. I was convinced that they were going to be melted after reading ALL of the posts on this forum. To my surprise, after almost 2 seasons of drag racing, they are in PERFECT condition. I am a firm believer that your tuner has everything to do with HF cat failure. I went ahead and installed off-road pipes just to be safe, but I thought you'd like to know.
Magnacharged L99, 3.4 pulley, 9.5 psi, CAI Inc cold air intake, ID-850's, ZL1 pump with ADM FPCM, MT 305/45R18 DR's, 17x4.5 Race Star front skinnies, Stainless Power LT 1 7/8 headers & off-road pipes, BMR rear suspension goodies, JRE Super tensioner, JRE race scoop, Borla S-type and tuned by Jannetty. 11.08 at 124.5 mph with a 1.62 60' is my PB to date.
03-28-2015, 08:15 PM | #7 |
Drives: 2013 ZL1 Camaro 2000 SLP Camaro Join Date: Oct 2012
I would go catless and be done with.
2013 ZL1 748rwhp & 733 rwtq ( 93 tune )
03-28-2015, 09:55 PM | #8 |
JT Synergy RS/2SS
I agree, just wanted to let everyone know. It's cheap insurance. I was shocked at how great mine looked!
03-28-2015, 10:20 PM | #9 |
whippled 5th gen
had my cats gutted few months ago best decision I even made after seeing two different friends cars, clog their cats.
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
03-28-2015, 11:13 PM | #10 |
Drives: 2SS/RS Summit White Black Stripes Join Date: May 2010
Can't you just use high flow cats and then gut them? After all a gutted cat is better than off-road pipes because if you get a spot inspection done if you get pulled over or anything it still looks like you have cats put on instead of off road pipes.
03-30-2015, 12:46 AM | #11 |
whippled 5th gen
I had the kooks high flow cats and gutted then for the visual inspection and didn't want to deal with a clogged cat down the road.
04-25-2015, 01:35 PM | #12 |
Drives: Camaro 2SS 2013 Join Date: Sep 2014
what sound difference it make with HF cats and Off Road pipes. With regards to deep rumble and raspy
04-27-2015, 08:58 AM | #13 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
It is a very small difference. It is a little louder, not sure I would say "deeper", definitely not "raspy" to me. I also have cutouts, and it is definitely Louder with them open, that is where I can hear the difference more.
