11-01-2014, 10:23 PM | #1 |
Drives: 2011 Camaro SS L99 Join Date: Jan 2012
Removing Front Sway Bar
I have read a number of other threads on this subject, and I have seen opinions ranging from "no problem" to "OMG, you'll kill yourself". Not really interested in a lawyer kind of reply, but rather an analogy to the handling characteristics of another vehicle.
I have a raggedy 2002 Silverado 1500 extended cab that I DD, and I'm wondering how a 5th Gen w/o a front sway bar would drive/handle compared the truck. My 5th Gen is basically only driven to/from the drag strip and on the drag strip. Thanks. |
11-01-2014, 10:41 PM | #2 |
Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
I have no personal experience driving a Camaro with no front sway bar but I think you will be OK. Just don't take any hard turns. The weight transfer will be good for drag racing though.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
11-01-2014, 11:12 PM | #3 |
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX Join Date: Mar 2011
It drives very much like stock until you get into hard cornering. There the body rolls pretty badly without the front sway. Just like the 4th gen f-bodies did. For a street/strip car that is not daily driven you should be fine.
2011 Camaro 1SS
Whipple Supercharged street monster |
11-02-2014, 07:46 AM | #4 |
Drives: 99 Camaro; 2010 Camaro 2SS/RS Join Date: Nov 2009
I'm not sure you need to remove it. I run the stock sway on my car and former member Z1 Dunn. Z1 dunn has been 1.43 ave 1.45-46 on M&H dr.
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146 |
11-12-2014, 09:24 PM | #5 |
As a follow-up I wanted to let you know that I removed the front sway bar, and quite frankly, I don't notice that the car handles one iota different than it did with the bar. I've tested the handling pretty aggressively, making quick lane changes on the Interstate at up to 100 MPH, and notice no difference. So I guess I won't "shoot my eye out" because of no front sway bar.
11-12-2014, 09:30 PM | #6 |
Drives: 14 1SS Camaro 1LE, NPP, Recaros Join Date: Nov 2013
Just remove one end link to try it before making the decision
11-14-2014, 08:56 AM | #7 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
I see you already did it, I guarantee if you try any quick corners or emergency maneuvers on wet pavement you will get a different result as the car will oversteer.
Drive it normal and you will be fine
11-14-2014, 12:05 PM | #8 |
Car does not leave the garage in rainy weather, as it has drag radials on the rear which would scare me more than the sway bar. Car is not DD, and only is driven to/from the track. I've put a total of 10,000 miles on the car since I bought it nearly 3 years ago. Any vehicle, front sway bar or not, is going to be squirrely on wet pavement.
11-21-2014, 09:23 AM | #9 |
Fight Crime, Drive Armed
Drives: '14 2SS Yelo Maro, HD collection Join Date: Jun 2013
I'm with you on the low mileage thing. Camaro is not my DD and I didn't break 2000 miles in the first year of owning it.
For a drag car, whatever gets you weight transfer in a safe manner (especially your FREE mod) is cool. Just don't drive it around.
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
