03-09-2021, 09:11 PM | #1 |
Drives: 2015_1le Join Date: Apr 2014
Recent Tune... lot of smell
It seems that they are differing opinions on this... got my tune done about 10 months ago... it idles at around 1K or so now, and smells like fuel, always... is it going to blow up, or is it just running rich which makes the motor last? The tuner had a reason for it and I think he mentioned overlap... it's a blower cam... should I get it re-tuned somewhere?
03-09-2021, 09:17 PM | #2 |
Drives: HHR Join Date: Dec 2015
Do you still have cats?
If so, raw fuel will kill them faster. |
03-09-2021, 11:00 PM | #3 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
Injector timing can be adjusted to reduce/eliminate the raw fuel smell when you have a larger than stock cam installed. The settings in the tune are around EOIT (End of Injection timing). If the injector is flowing fuel when the exhaust valve is open/opening then that's what you get - raw fuel smell. It takes a pretty savvy tuner to adjust these settings but there are some calculation tools out there to help.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
03-10-2021, 03:24 AM | #4 |
03-10-2021, 03:26 AM | #5 | |
Thanks! |
03-10-2021, 09:16 AM | #6 | |
Drives: 2015 zl1 m6 Join Date: Jan 2020
You should talk to your tuner or if he can’t do it then find another .. |
03-10-2021, 01:46 PM | #7 | |
