02-25-2016, 02:17 PM | #1 |
Drives: 2010 2SS/RS Camaro Join Date: Aug 2014
HAS ANYONE USED THIS GAUGE POD FROM AUTO METER?
I am adding a couple of after market gauges to my 2010 SS Camaro & was wondering if anyone has installed the TWO GAUGE POD from Auto Meter that fits in the center console just in front of the shifter?
It holds two 2 1/16 in.diameter gauges & sells for about $72.00. If you have it in your Camaro, were you satisfied with the fit & quality? Thanks in advance for your help! All The Best Orange 2010 Camaro |
02-25-2016, 02:59 PM | #2 |
Drives: 2015 1SS 1LE Join Date: Sep 2015
I installed this recently. Got it from Phastek. Very satisfied. Looks like it was always there.
02-26-2016, 06:42 AM | #3 |
Drives: 2010 Camaro RS/2SS Join Date: Sep 2015
It looks pretty good, but mounting gauges that display information out of line of sight kinda defeats the purpose. If you take your eyes too far off the road etc., you not only endanger yourself, but others around you.
I'd recommend sensitive gauges being installed on the pillar and then customize the console with some other kind of aftermarket gauge (oil temp, EGT, trans temp, etc.) Clean install though. Good work. |
02-26-2016, 10:10 AM | #4 | |
BUT you are absolutely correct. PSI is not sensitive because no one has ever blown a hose off, particularly the vacuum line operating the WG and then your WG doesn't open and you grenade your motor. You've got it all figured out. I'm just impressed you got a wideband and not a discolight. Anyways.... |
02-26-2016, 01:59 PM | #5 | |
By the way I am going to steel your idea on mounting the wide band AFR gauge in the drivers side AC vent! VERY CLEVER IDEA. I am also with you on keeping it NEAT & CLEAN. Thanks SO MUCH for all your help thus far! All The Best, Orange 2010 Camaro |
02-26-2016, 02:57 PM | #6 |
I can't take credit for that idea. I got the courage to do it from this thread by another member.
http://www.camaro5.com/forums/showthread.php?t=419870 It was very informative and made it a simple install. The actual gauge pod that goes in the vent is listed as a part for mustangs or f150's, but it works in ours with some minor trimming. There is a link to it in that thread I linked. As for the sensor I had a bung welded in behind the catalytic converter before I had long tube headers. Everyone will tell you to place it before the cats for the most accurate reading, but this was the easiest spot to access so I went with it. Probably makes the A/F read 0.1 leaner than it would before the cats. When I installed my long tubes, I had a bung welded into my off-road connection pipe (looks like a cat but it's not). In retrospect, I should have had them weld it on the front side of the "dummy cat" so the sensor is angled away from the exhaust flow but it's working well for now. Glad I could help! |
02-27-2016, 08:47 PM | #7 |
700RWHP-650TQ
Drives: 2011 Forged LS3 Supercharged/Cammed Join Date: Aug 2010
Hows this for right in your face!!
My setup.
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL |
02-29-2016, 07:57 AM | #8 |
02-29-2016, 08:13 AM | #9 | |
Drives: SS, CTS & SRT-4 Join Date: Aug 2009
01-24-2021, 12:51 PM | #10 | |
Drives: C5 LS3, C5 LS1, ZL1 LSA Join Date: Feb 2018
