07-06-2009, 08:28 PM | #1 |
Drives: 01 silverado 2010 2SS/RS Sim Join Date: Jun 2009
LS3 COOLANT TEMP
What coolant temp are you guys seeing on a 80* day , today coolant temps got up to 224* at a stop light so I pulled over to see if the fans are working and they weren't so I jiggled the wires and the fans came on , I don't know if it was just a coincidence they came on when I touched the wires or if that is the temp the fans come on seems a bit high .
07-06-2009, 09:41 PM | #2 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
yup, factory has a 195*f thermostat and the fans dont come on till over 220*f
i have a 160* thermostat and the fans programmed to come on earlier and mine stays at 170-185*f turn your ac on and your fans should come on
Similar Threads | ||||
corvettes LS3 vs Camaros LS3 | Caliman93230 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 13 | 08-21-2019 03:37 PM |
LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 10:56 PM |
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 07-30-2009 06:02 PM |
Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
LS376/480 EFI LS3 Gen IV V-8 | NOODLESgoneWILD | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 09-04-2008 08:14 AM |
