01-21-2013, 12:32 PM | #1 |
Drives: 2010 2SS/RS Camaro CGM Join Date: Aug 2011
Cheapest option for 18" wheels for DRs to clear Brembos...
Looking for the cheapest option in getting a 18" wheel to clear the Brembos for drag radials... weight is not a huge priority as I just want 2 for the rear, i'd even take a production wheel if they would clear...
2010 Camaro SS L99... has a few mods |
01-21-2013, 01:21 PM | #2 |
18x9.5" (+40 offset) reproduction Corvette wheels. I think most guys are using the C5 Z06 wheels. That is your cheapest option.
01-21-2013, 01:36 PM | #3 |
Drives: 2010 camaro pace car, 2008 cts bl, Join Date: Jun 2011
How about cheap front runners?
I have corvette GS wheels and 275/45/18 m&h dr's 50lbs
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
01-21-2013, 02:02 PM | #4 |
Drives: 2011 Camaro RS 2LT Join Date: Jul 2012
01-21-2013, 03:30 PM | #5 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
that offset is hard to find fyi. I'm using tsw nurburgrings...18x9.5...not bad high and lighter than a lot of drag wheel options to boot!
-John S.
01-21-2013, 03:43 PM | #6 |
http://wheelreplicas.com/camarowheels I thought this was yhe place most are getting them but I don't see 18x9.5 listed
01-21-2013, 03:55 PM | #7 |
http://www.wheelreplica.com/camaro.html this one shows them.
01-21-2013, 03:58 PM | #8 |
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
Why not get 10" wheels and 315 tires?
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
01-21-2013, 04:06 PM | #9 |
I honestly may run the stock wheels, I have OEM chrome wheels on my car and have the stock polished ones boxed up... may just throw a set of 305/35/20 Mickey Thompson ET streets on the 2 stock rear wheels and call it a day... think i'm going to throw 3.90s under the car and being its a L99, it will need plenty of tire, lol
01-21-2013, 05:03 PM | #10 |
It seems hard to find the offset needed on the wider wheels.
01-21-2013, 05:03 PM | #11 |
Drives: 1969 & 2016 Camaro SS Join Date: Oct 2008
You will have more contact patch if you run a 275 wide drag radial on that factory 9.0 rear wheel. The 305 will bulge badly, and your contact patch won't be flat against the road during acceleration. Need a 10.0 minimum wheel for a 305 wide tire, with 10.5 wide being perfect.
Fquick.com/NineBall
01-21-2013, 05:09 PM | #12 |
Drives: 2011 Camaro 2SS Join Date: Oct 2011
Nine ball I have 305 NT05Rs on 9.5" wide corvette grand sport wheels, I don't think it is bulging at all, certainly don't have traction issues.
01-21-2013, 05:29 PM | #13 |
instigator
that's bulging...see how the outside of the tread pattern is clean?
I run the same...305 on 9.5...while its not optimum, it does work at low pressure...like 15-17 psi because the contact patch is all the way across the tread at launch.
-John S.
01-21-2013, 08:31 PM | #14 |
Well smack my a$$ and call me shirly, I never noticed that lol. But there they are aired up to 38 PSI and when at the track as you said at 15-20 PSI they wear very different (in a good way)
