07-13-2014, 07:47 PM | #1 |
Drives: '21 ZLE A10 Join Date: May 2012
Easy underhood "fan on" and "IC pump on" switches
No pics...sorry but it is incredibly easy to install these two switches. Get two simple on/off toggles with two poles as a circuit interrupt. The fan switch is easily situated near the fuse box and the 12v+ lug is on the front of the fuse box. Strip back the black finishing tape from the fan connector and scotchlock on the light blue wire for the low speed fans (they both turn on). Run a 14-16ga wire from the scotchlock to one of the poles of the switch and the other pole of the switch to the 12v+ lug on the front of the fuse box...one done. The intercooler pump switch is a little more difficult as you must remove the belly pan and remove the connection to the underside of the IC pump. Strip back the black tape on the wiring harness to the IC pump...3 wires...2 light brown and one black. Use a flashlight to see the pin connection numerals embossed in the pump as pin 1 is the switched 12v source (far right light brown/tan wire on my plug) and it is the wire you need to scotchlock with a 14-16ga wire and run up towards the jump stud near the driver's shock tower. Same deal as the fan switch...one wire from the IC pump scotchlock to a pole on the toggle. Run a wire from the 12v positive lug(it unscrews with a 13mm socket to reveal a stud) to the other pole of the toggle. That's it. Ask questions if anything seems confusing. Reference post for IC pump wiring plug for confirmation...http://www.camaro5.com/forums/showthread.php?t=255716
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold) '15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold) '12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold) Last edited by Stephen12ZL1; 07-13-2014 at 08:30 PM. |
07-13-2014, 08:27 PM | #2 |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
Awesome post!
07-13-2014, 09:07 PM | #3 |
Drives: none Join Date: Aug 2011
Every ZL1 owner that spends time at the dragstrip needs to do this.
Well, unless they just do it through HP Tuners like I do. |
07-14-2014, 07:28 AM | #4 |
Drives: 2017 ZL1 A10 Join Date: Sep 2009
This DIY should help also.
http://www.camaro5.com/forums/showth...51#post6584351
2017 ZL1
A10 Redhot with stripe |
07-14-2014, 11:39 AM | #5 | |
07-14-2014, 09:03 PM | #6 |
Drives: 2012 Camaro ZL1 Join Date: Jun 2014
Curious... Why the low speed wire and not high speed?
07-14-2014, 10:44 PM | #7 |
Amperage. I also have the ic pump on the same circuit. Plus, I only make one run per hour, so I really don't need the extra air. After running the fan and ic pump for 15 minutes, the air through the radiator/ ic is as cool as the ambient air.
2017 ZL1
07-14-2014, 10:46 PM | #8 |
Cool. Glad I could help.
2017 ZL1
07-14-2014, 11:26 PM | #9 |
Going for Plaid
Drives: 2011 C6 Join Date: Jan 2010
Can you do that without tuning the car? I've got HPT Pro, but don't want to ditch my warranty quite yet.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance. 2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14) |
07-15-2014, 12:38 PM | #10 |
07-15-2014, 01:43 PM | #11 |
Going for Plaid
07-16-2014, 02:00 AM | #12 |
Might want to at least throw a fuse inline. Just sayin'... Fires are no fun. Personally, I am paranoid and put in diodes, too...
1968 SS w/ 1966 427/425 Sequoia Green w/ Bumble Bee stripe. Always working on it... Drooling over the ZL1s. It will be my next car if I can manage to pull it off... |
