12-29-2014, 04:15 PM | #1 |
Drives: Lemans Blue with White stripes Join Date: Jul 2009
Need help installing throttle arm
Has anyone installed throttle arm on cowl induction?The area where it goes is real tight for space to work.doesnt look like there is enough to grab at the end of gas pedal rod to attach.
12-30-2014, 03:16 PM | #2 |
My gas pedal is crossram style,could this be what causing the problem to connect throttle level?
01-26-2015, 07:18 PM | #3 |
I would say yes.
I believe the cross ram set up goes down the middle of the carbs. The single carb set up may be more to the driver's side? I've had many different intakes and carb set ups on my '68. The arm that connects to the firewall is stock and has worked with all of them. I thought the cross ram used a cable? I know that the cowl induction hood arm is specific. Not sure if there is one specific to that hood and manifold combination.?.?
1968 SS w/ 1966 427/425 Sequoia Green w/ Bumble Bee stripe. Always working on it... Drooling over the ZL1s. It will be my next car if I can manage to pull it off... |
