12-24-2014, 10:27 AM | #1 |
Drives: 1990 IROC-Z Join Date: Dec 2014
Heater control valve
I have a 1990 5.7L TUNED PORT INJECTION IROC-Z the vacuum line is missing from it. I need to know where it is located.
12-26-2014, 12:00 AM | #2 |
Drives: 69 Camaro and 92 RS Join Date: Feb 2013
You should find your answer somewhere in all this info.
http://www.thirdgen.org/forums/inter...ter-valve.html http://www.thirdgen.org/forums/tech-...ve-vacuum.html http://www.thirdgen.org/forums/tech-...iagrams-i.html
There are 3 ways to do any project. Good, fast, and cheap. You can only choose two.
If it's done good and fast, it isn't going to be cheap. If it's done good and cheap, it isn't going to be done fast. If it's done cheap and fast, it isn't going to be good. |
