Old 11-01-2011, 07:04 PM   #1
dcamaroguy
dcamaroguy
dcamaroguy's Avatar
Drives: IOM 2010 Camaro 1SS/RS LS3
Mirror replacement
Has anyone had to replace or know how to replace the passenger side mirror assembly? Got too close to the garage door rushing my son to football practice and cracked the assembly.
dcamaroguy is offline   Reply With Quote
Old 11-01-2011, 07:10 PM   #2
DeacSS
DeacSS's Avatar
Drives: 2010 Black LS3 SS/RS
I had to replace mine after my car was vandalized, someone decided to take it off in a parking lot. The dealer told me it was only repaired in one piece so that the whole assembly needed to be ordered painted and then replaced, even though the mirror was intact and only the bracket attaching it to the car was broken. I was in a hurry to get it fixed so I let the dealer do it without getting a second opinion from a body shop, wasnt too costly and was back after being painted in a couple of days. Install took a little over 2 hours or so.
DeacSS is offline   Reply With Quote
Old 11-01-2011, 08:41 PM   #3
Top Thrill
BOD 5/28/09 #13485
Top Thrill's Avatar
Drives: 2010 Camaro 2LT RS
Yah, I had to fix mine about two weeks ago.
Top Thrill is offline   Reply With Quote
Old 11-01-2011, 08:48 PM   #4
MG
MG's Avatar
Drives: 2011 Camaro
http://www.camaro5.com/forums/showthread.php?t=155089
Top Thrill, how did you go about fixing yours? It looks like the screws were forced out of the thread in the bracket, no?
MG is offline   Reply With Quote
Old 11-01-2011, 08:57 PM   #5
Top Thrill
BOD 5/28/09 #13485
Top Thrill's Avatar
The studs pulled right out of the mirror and where still bolted in the door. I took the inside door cover off. Removed the studs, epoxied them back in the mirror. Let it set up good and put it all back togeather. Took about 3 hour including the 1 hour wate time for the epoxy to set.
Old 11-01-2011, 08:59 PM   #6
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
You can buy individual parts for the mirrors from GM partshouse according to their site.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 11-01-2011, 09:02 PM   #7
MG
MG's Avatar
Drives: 2011 Camaro
The link I posted was a DIY on replacing the mirror.
Does anyone know how if the mirror assembly can be removed from the mirror case?
Old 11-01-2011, 09:17 PM   #8
The Stig
knows 2 facts about ducks
The Stig's Avatar
Yes. Once you remove the mirror from the door you basically need to go at it with a tiny screwdriver and remove all of the small screws.
Click to view my build thread
Old 11-01-2011, 09:22 PM   #9
Top Thrill
BOD 5/28/09 #13485
Top Thrill's Avatar
I hope this works.
Old 11-02-2011, 06:54 AM   #10
dcamaroguy
dcamaroguy
dcamaroguy's Avatar
Thanks for the help. Ordered the part from GM Parts Direct and a friend is going to paint it.
