Old 05-12-2014, 09:24 PM   #1
bcguy
bcguy
bcguy's Avatar
Drives: 2011 ss/rs m6
Opinions on high end fuel systems
I'm about to join the 1000 plus club wanted some of your opinions on fuel systems. Probably 1600 size injectors and which fuel system is the best out of the top names. Pros and cons. Have Lonny's dual fuel now and will call him tomorrow to see if maybe it can be upgraded. Thanks
Agp 62/66 ,lsx 427. , Callie's ,diamond ,all pro ,American racing ,I'ds130s,102 intake and throttle body,etc .fore triple , Turbo 400 level 5 , b and m pro , dss carbon fiber , dss ford 9 inch with strange pumpkin,3.73 ratio,1400 hp axels,boost and air fuel pillar guages. Weld rts 17x10 and 17x4.5 with m and h drag radials and skinnys
bcguy is offline   Reply With Quote
Old 05-12-2014, 09:58 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Squash dual 405s/450s (E85 version). I use it and so do several others. Not a single issue and I have not heard a single complaint about the system. It is a return style system though.
Old 05-12-2014, 10:02 PM   #3
bcguy
bcguy
bcguy's Avatar
Ok thanks. Anyone hear much about the fore system
Old 05-12-2014, 10:11 PM   #4
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Fore and Squash are both outstanding. I have the squash dual 405s and recently made 1280 rwhp with no issues on pump/meth. I have heard good things about Lonnies just not real popular here for whatever reason.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 05-12-2014, 10:21 PM   #5
bcguy
bcguy
bcguy's Avatar
The Lonny's has worked for my 640 to the rear but it's a pretty big step to where I'm going.will look into it tomorrow. Thanks again gentelmen
Old 05-12-2014, 10:22 PM   #6
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
I've been through several different iterations...
Started with the Lingenfelter duals, and then added the BAP... This was fine up to around 800 rwhp...
We tweaked the system a bit and upgraded to the Aeromotive big boy, and it lasted a grand total of less than 7 hours total run time... It failed and while we sent it back and Aeromotive "fixed" it, I have no trust of it and will not ever run their pumps again...
So, we built a sump that mounted below the previously existing wheel well... which has been cut out and removed...
We put the Lingenfelters back in the tank and run them wide open with no back pressure to the sump via a dash 12 line. From the sump, a Weldon external draws off and pumps it forward to the rails... We were running one Weldon DB2025-A but we are now adding another one...
With one, we were able to make 1440 rwhp.
The single weldon ran at low speed until 1 lb of boost, then a HOB switch turned it up to high speed. We are also runnnig a BAP on the Weldon.
We will now run two of the same pumps. One as it is set up now, and a second one that will only run from 18 lbs of boost up and it will only run at high speed...
It's working for us... so far...
Old 05-12-2014, 10:57 PM   #7
bcguy
bcguy
bcguy's Avatar
That sounds definitely high end. Thanks for the input. Did u guys cut the access hole under seat to maintain this stuff or go the long route
Old 05-12-2014, 11:00 PM   #8
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I went the long route. Next time, I will cut an access hole in the floor.
Old 05-13-2014, 12:19 AM   #9
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
No hole cut in ours... We pull the tank if we need to access it...
Old 05-13-2014, 01:21 AM   #10
BullF-16
BullF-16's Avatar
Old 05-13-2014, 07:11 AM   #11
realsquash
realsquash's Avatar
Drives: Four Door Camaro
I heard the Squash setup is super pimp! Hah!
Squash Performance LLC
2010+ Camaro 800 LPH fuel systems
realsquash is offline   Reply With Quote
Old 05-13-2014, 04:49 PM   #12
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Diggin' my Squash return style setup! Works great!
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 05-13-2014, 05:34 PM   #13
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Howzaboud the returnless?
Iam Broke is offline   Reply With Quote
Old 05-13-2014, 08:15 PM   #14
bcguy
bcguy
bcguy's Avatar
So I got a pm from a c 5 er that has a triple fore system for sale. Didn't have time to call the dealers about it as it was late In the afternoon Anyone have anything to say about this system It's unused and a couple years old
