05-04-2021, 10:27 AM | #1 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
Intake Manifold Options
So I currently am running a Holley Sniper Low Pro EFI intake on my car, and its garbage. Does anyone run a single plane and an elbow that will fit under the factory hood?
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
05-04-2021, 10:55 AM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Have you looked at the LOD?
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
05-04-2021, 02:46 PM | #3 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Victor JR does with the Edelbrock elbow. Holley is even lower so either will work. I’ve seen a 500whp car with that combo
05-04-2021, 03:57 PM | #4 | |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
I had a weird harmonic noise with mine that I had to fix.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
05-04-2021, 05:41 PM | #5 |
Drives: 2015 1LE Join Date: Oct 2015
I don't think LOD makes those intakes anymore.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
05-04-2021, 05:45 PM | #6 |
Why is it garbage? I would think with a supercharger it would not matter too much.
05-04-2021, 09:03 PM | #7 |
Drives: 2010/2SS/M6/440ci Join Date: Jan 2018
I can assure you we certainly do still make the X1 we're on version 3 now
2010 2SS Camaro - Engine: 5.3 aluminum Re-sleeved 4.185 bore, 4 inch stroke, 12.5:1 compression, 440ci, SPS Dart pro1 ls3 heads, tsp ls7 stage 4.2 cam(too small), "billet bill" original X1 manifold, bbk 102mm, cai cold air. Exhaust: TSP 2 inch primaries, V-band merge, hooker blackheart x pipe (modified) spintech 9000 mufflers. Drivetrain: Dss 1 piece driveshaft, MGW shifter, Z28 clutch, ram aluminium flywheel. Body: ZTA spoiler, de-badged, ZL1 front bumper, 14-15 mohawk, two tone paint.
05-04-2021, 09:11 PM | #8 |
Here's one of our most recent customers. Fits under the cowl and factory strut tower brace.
05-05-2021, 10:15 AM | #9 |
The fittings and placement are the worst, the noise, I had to have it machined to fit larger fittings for my brake booster to ensure my brakes work. Every season I have had to tinker with this cheap intake. 3rd year, 3rd set of intake seals to be replaced.
05-05-2021, 10:52 AM | #10 |
Yeah... not sure where you heard that????
05-05-2021, 12:53 PM | #11 |
This for the win!!! Thanks Raf, love mine still!!!
05-05-2021, 03:12 PM | #12 | |
I also drilled and tapped a few of the holes to except bigger lines, and just recently added a line on the passenger side of the tbody because adding it there was faster then pulling the manifold to use one on the bottom that I had put a plug on LOL I have not had seal issues yet, but I also have not put more than 2000 miles on it yet...I hope I don't run into those issues.
05-06-2021, 01:52 PM | #13 |
I am looking at just doing the BTR, looks sturdier, and the fittings in the right spots for what I want to do
05-06-2021, 03:12 PM | #14 | |
I will run mine a little longer and see how it handles itself in the next few weeks.
