11-15-2021, 06:18 PM | #1 |
Drives: 2010 Camaro SS Join Date: Dec 2006
“Boosted” vs standard throttle bodies
Can someone explain the significance of a “boosted” throttle body (Nick Williams, etc) vs a standard version? I remember reading about this in the past. If memory serves us right…this was all related to turbo push boost over the throttle blade leading to fluttering? Trying to confirm if the standard version works fine for a supercharger.
11-15-2021, 07:22 PM | #2 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Correct
Some have seen issues with the either the blade closing against boost or, as you said, fluttering, when there is no pedal demand |
11-30-2021, 12:39 PM | #3 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
I haven't heard of anybody with a S/C having this problem.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
11-30-2021, 01:02 PM | #4 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Just to clarify. The new NW 103mm (not 102) work with either application.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
11-30-2021, 01:03 PM | #5 |
Sucky chargers no, blowy chargers or turbos yes.
11-30-2021, 01:59 PM | #6 |
Drives: 2011 Camaro SS Join Date: Jul 2017
So with the stock TB and a turbo kit would it be better with a NW boosted 103 TB?
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
11-30-2021, 02:22 PM | #7 | |
I guess I didnt clarify very well. Nick Williams sold a 102mm standard and 102mm boosted TB. In the 103 version (which fits all 102 openings) they only have one version. It works with either NA or Boosted applications. Any type of boost. Have I lost everyone?
11-30-2021, 02:44 PM | #8 |
Drives: it changes Join Date: Nov 2010
11-30-2021, 03:03 PM | #9 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Ya. The stock TB will suffice, even blowing 27psi through it with turbos (not 2000hp in my case).
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
12-01-2021, 12:38 PM | #10 |
Even though the stock intake/tb will “support” 1700whp, that doesnt mean you cant gain hp/tq by opening up the intake track. Maybe someone doesnt have unlimited boost pressure on tap, to just turn the dial.
I just bought a Pro Flo and nw103 tb. Im gonna retune and hit the dyno at the same boost level. See what happens…
12-01-2021, 03:03 PM | #11 |
My intake is a rod mod ported unit and I was curious if I needed a NW unit but it sounds like a stock TB will support more power then I'm putting out and handle the boost.
12-01-2021, 05:58 PM | #12 |
I had a brand new NW 103 TB and sold it to a fellow member on here for his 2.9 Whipple setup. He was running a ported stock TB and after the NW install he picked up 40rwhp more than he had. He's happy..
12-01-2021, 06:12 PM | #13 | |
Drives: 2014 1SS/1LE Join Date: Nov 2015
12-01-2021, 08:19 PM | #14 |
That’s what I’m hoping for given my similar set up with a Kenne Bell 2.8. I know twin screw superchargers like as wide open of an intake as possible. Very different air dynamics from turbos when they are pulling air instead of pushing it though the throttle body.
