Old 04-19-2010, 04:06 PM   #1
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
One Wheel Burnouts
Why does my car do one wheel burnouts? At the track last week every time I did a burnout in the water box both tires would begin spinning but the left one would stop while the right one continued to spin.
Here's some examples:
2019 ZL1 1LE | M6 | SGM | PDR | CF Dash | Nav | Wheel Locks
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses
Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6
YouTube
RamAir02 is offline   Reply With Quote
Old 04-23-2010, 02:14 PM   #2
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
Maybe your limited slip isn't working. Clutches? Still ... you had great runs.
Cam 427 is offline   Reply With Quote
Old 04-23-2010, 02:56 PM   #3
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
I think you would be worried about the flames under your car in the 3rd video. Do you have cutouts?
Scott@Bjorn3D is offline   Reply With Quote
Old 04-23-2010, 09:25 PM   #4
jrpxxii
jrpxxii's Avatar
Did you have traction control completely off? I think it is the mode traction control you had it on. You need to hold the traction button down for seven seconds to disable it completely for a nasty burnout.
Old 04-23-2010, 09:41 PM   #5
RamAir02
RamAir02's Avatar
Traction control was held down to disable all systems. The traction control as well as stability control systems were completely off.
YouTube
Old 04-23-2010, 10:10 PM   #6
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
WOW WTF,
And WTF where the flames all about
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 04-26-2010, 11:55 AM   #7
Russell James
Russell James's Avatar
Do you have line lock?
My guess would be no, and when your jumping on the brakes it's trying to grab the rears. The power is overpowering the right brake and the diff clutches. And by the looks of the sparks its blowing through the clutch too.
If your going to be doing burnouts, I'd put line lock on it. Or start the burnout back in the water and roll out spinning the tires. Dumping the clutch on the dry and then jumping on the brakes is murder on the clutch and diff.
Old 04-26-2010, 12:59 PM   #8
Reeko
Drives: 69 Camaro RS Conv. 2010 Camaro SS
Have you changed your diff fluid?
Perhaps you added too much of the LS additive.
Reeko is offline   Reply With Quote
Old 04-26-2010, 01:19 PM   #9
Stingr69
'69 Owned Since '79
Stingr69's Avatar
+1
Any non-GM spec fluids or additives in there?
-Mark.
Old 04-26-2010, 03:38 PM   #10
RamAir02
RamAir02's Avatar
No idea what that flame is. I never noticed it until you guys pointed it out.
I do not have a line lock on the car, but one is planned in the near future. I had a line lock on both my '99 and '00 Trans Ams and loved it.
As far as diff fluid, it hasn't been changed. Still the same diff fluid the car came with from the factory.
I still don't know why my car does one wheel burnouts!
YouTube
Old 04-26-2010, 03:44 PM   #11
n!ght r!der
That Guy
n!ght r!der's Avatar
Drives: really good
Originally Posted by Jeanius View Post
WOW WTF,
heated seats lol
n!ght r!der is offline   Reply With Quote
Old 04-27-2010, 07:45 AM   #12
Russell James
My guess is the spark shower is from the clutch. Cars with real strong brakes .... i.e. Brembos, are real tough on the clutch doing a burnout that way.
I think what is happening is your jumping on the brakes hard, and then I can hear the throttle/RPMs going up and down. I'd bet when the power is off a bit for a split second, the left brake grabs, when you get back on it - that brake is stronger than the diff clutches and all the power is now going to the right wheel.
Once one brake grabs, all the power is going to be going to the other wheel and it will be easy to overcome the brake power on that side. Then I think the next time your revs and power went down, your right brake tried to grab and tire got sticky, and when you stood back on the power, it blazed the clutch.
I think the trick is to start the burnout in the water and stay on the throttle hard with just enough brake pressure to keep it from rolling forward too much. But as soon as you let off the throttle, that's it. If you jump back into the throttle after the tires or brakes have grabbed, it's going to blow through the clutch.
When burnouts aren't going so good, most often the cure is - more water and staying on the throttle harder. If your going up and down with the throttle and either the brakes or the tires start to grab, it's going to go wrong from there.
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 05:00 PM
*LIMITED QUANTITY* Status knight 816 Wheel Blow-out SALE $1120.00 SHIPPED!! BestWheelDeals Wheels / Tires 30 09-04-2010 05:16 PM
GM - flare out the front wheel wells a little to protect the gills? sen10l 5th Gen Camaro SS LS LT General Discussions 2 03-19-2010 06:30 PM
