10-22-2011, 10:28 AM | #1 |
Drives: Black on Black 2SS RS A6 Join Date: Nov 2009
Emergency Brake Cable Rub
I just lowered the car an inch and now my E Brake cable rubs on my 18 inch Z06 Wheels with the DR's I have heard of this problem, but thought it was limited to the 17inch Bogarts?
Has anybody come up with a good solution yet? |
10-22-2011, 02:13 PM | #2 |
Drives: BLACK 2SS/RS Join Date: Sep 2009
The easiest and most secure method seems to be to remove most of the slack but allow enough for wheel/suspension travel then cut a piece of fuel line that has the same ID as the Ebrake cable and then slide this hose around the cable to protect it and use Stainless hose clamps to clamp it just behind the first retaining bushing. This prevents it from creeping back towards the wheel. Have had no issues for the past two+ years. See posts 5 & 52 in the link below.....
http://www.camaro5.com/forums/showth...t=Ebrake+cable Here is a pic i took looking thru the wheel spokes....
CCW polished 505a's
Front 20x10 w/275/40/20's Rear 20x11.5 w/305/35/20's Eibach 1" Pro Spring Kit Factory GFX MPD1 spoiler painted bowties 15% tint |
10-22-2011, 03:13 PM | #3 |
Slow Turtle
Zip tie or clamp it by the bushing to your toe rods
Similar Threads | ||||
Stainless Works Longtube w/High Flow cats plus Hawk Ceramic Brake Pads | Xplosive Performance | V8 Bolt-Ons & Tunes | 35 | 09-17-2011 11:03 AM |
C6 Z06 drag wheels. How did you tie back your brake cable? | jasycz28 | Dragstrip and Launch Techniques Discussion | 5 | 03-07-2011 10:23 AM |
***STILLEN Camaro5 SS Brake System Upgrade Package*** | Team STILLEN | Suspension / Chassis / Brakes | 20 | 08-06-2010 10:49 AM |
Brake upgrade | 96CAMaro | Wheels and Tires Talk Sponsored by The Tire Rack | 28 | 06-03-2009 01:44 PM |
Emergency brake lever | Vash | Cosmetics and Lighting Modification Discussions | 12 | 08-25-2008 03:53 PM |
