Old 03-02-2017, 06:31 PM   #1
JHurt
Drives: 2014 Camaro V6 RS
flashing fast, will it harm anything
This video, its a update to the last, the one with the red turning signal. 1) there is less lit area, they show better. 2) with hazard light, they blink normal, but when turn signal, they blink faster,, will this harm anything, thanks for your time. video below
https://youtu.be/OaiVwqOJCr0
JHurt is offline   Reply With Quote
Old 03-02-2017, 06:41 PM   #2
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Go get that looked at ..they shouldnt flash that fast.
rontammy0 is offline   Reply With Quote
Old 03-03-2017, 03:16 PM   #3
JHurt
Thanks, I was thinking of trying to find red bulbs that are normal bulbs, I mean not LED. It wasn't until the LED that it started
Old 03-03-2017, 11:26 PM   #4
Candr3535
Candr3535's Avatar
Drives: 2013 ZL1 Triple Black Vert M6 #5591
If you added LED bulbs. You need resistors for that circuit, otherwise they will just blink fast. Not gonna harm anything. Good luck
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice..
Candr3535 is offline   Reply With Quote
Old 03-04-2017, 02:56 PM   #5
JHurt
Thanks Candr3535, I asked if I needed one, a resistor, and the guy at the auto store said I wouldn't.. I was wandering that.. I will pick one up.. Thanks again
Old 03-04-2017, 03:26 PM   #6
RiveradoZ71
RiveradoZ71's Avatar
Drives: 2015 2SS/RS 1LE
It's called Hyper flashing. You need resistors as states.
RiveradoZ71 is offline   Reply With Quote
