09-06-2014, 01:22 PM | #1 |
Drives: 2011 2SS/RS L99 RJT Convertible Join Date: Sep 2014
Supercharged/Mods: Factory or DIY
I've pretty much decided on a Gen5 convertible(an easier sell to the old lady) and will definately will be doing FI on the car. My previous car was a Dodge Magnum SRT8 with a V3 Vortech supercharger. It had many suspension/engine/interior/brakes/exterior upgrades. Only drove it to shows and "really" nice days. The car was more of a hobby then anything else, but just like anyone who has done extensive Mods your lucky to see 50 cents on the dollar at sell time.
So, here's my dilemma, do I go with bone stock 1SS and do everything again(which I really enjoying doing as a backyard mechanic) or do I try to get a stock IE. ZL1 on the cheap or start with something in-between IE. 2SS/RS? Starting bone stock is alluring as I can put the best of what I can afford on the car and it makes it more my own. The ZL1 route is attractive because of any warrenty issues and you are pretty much ensured everything plays nicely together, stock anyways. I'm a huge fan of buying used, so whatever I get will be from the web. Less then 10k miles(hopefully not a 1/4 mile at a time). There's some good deals every now and then, but I just get a little gun shy as I I'm on the fence to which direction I want to go. Any advice? |
09-06-2014, 01:56 PM | #2 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I buy lots of used parts for all my vehicles. I just factor into what I am willing to offer the additional time it takes to work with used parts. and the possibility I may have to fix the part. Some people feel like your lowballing them, but nothing goes in as well the second time it's installed.
Along the same lines, if you buy somebody else's build, you have to factor in what they may have cut corners on. I would look for things like crimp on electrical connectors (or worse twisted and taped wiring), poor fitment, illogical build, etc. What I mean by illogical build is things like, a blower with the smallest possible pulley and untouched fuel system? (same for nitrous) a .600+ lift cam with stock springs? You sound like you know what a hackjob looks like and what a car should sound like. I always think about if something is done to the standards I would do it. If you see little things that are shortcutted, there going to more when you dig in. Not to say you should automatically disqualify the vehicle, but factor the extra time required in the price. Sometimes I wish I had waited a couple years and bought a used SS with a blower already on it. Time is money and my wife thinks I love the car more than her already. However, when I saw them come out in 2009, I had to have one. If you can't find a built car that you love, buy a stock one and go to work.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
09-06-2014, 05:58 PM | #3 |
Drives: 2010 SS L99 IOM Join Date: Aug 2012
IE do you mean 1LE?
A 1LE would be a good base to start with imo.
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins |
09-06-2014, 07:12 PM | #4 |
Banned
Drives: Camaro Join Date: Mar 2013
IE means for example.
09-06-2014, 08:03 PM | #5 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
Or Internet Explorer....
id est (i.e.), usually used in context for "that is," "which to say," or "for example" I agree, if the mods are done RIGHT, then buying modded can save a buttload of time and money, as usually a modded car brings a bit less than an untouched original. But it always varies.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
09-06-2014, 08:08 PM | #6 |
Drives: 2013 Camaro 2SS RS Convt. Join Date: Mar 2011
I started out with a 2SS/RS and built it from there.
If I were to do all over again, I probably would of started with a ZL-1 instead. I could be wrong, but I believe the LSA engines have a stronger bottom end, and therefore might hold up better to additional HP. Good luck in your search and welcome to Camaro5!
2013 Nickey Stage II Camaro SS Convertible #10.Black w/ Red leather interior. No Weeds Elec. Diverters, CNC ported heads, custom grind cam, upgraded fuel injectors, ZL-1 fuel pump, V-Max ported TB, Red Magnuson Super Charger with rear cog drive, upgraded rear axles good for 1400Hp, 3:45 gears, Tremec 6 spd., Pedders adj. coil overs, Phadt ZL-spec swaybars, 800Hp at the crank, 670RWHP, 613ft.lbs. torq. @ 11lbs. boost. SOLD!!!
09-06-2014, 08:12 PM | #7 |
Drives: 2010 1LT/RS Transformer Edition Join Date: May 2014
IE = In Example lol
Injen CAI, Apex Catch Can, Vmax PTB, Black Ice-olator, Solo Performance Mach X-LLT Cat-Back, SLP Flat Black Gill Stripes, Satin Black ZL1 Repro Wheels, Vitesse Throttle Controller.
09-06-2014, 08:29 PM | #8 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Look on the ZL1 section...looks like lots are having the super chargers replaced under warranty
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
09-06-2014, 11:21 PM | #9 |
Drives: '11 Camaro Supercharged Convertible Join Date: May 2014
I started from the ground up with a convertible. This was before the ZL1 was introduced. I enjoyed building it myself, but it did take a toll on my wallet. I'm currently at a crossroads because it's done. Motor, drivetrain, suspension etc. I'm deciding whether to sell and start a new project or find new things to do. I will say that if I could do it again, I would, but I would look into parts being sold by members. You will save a lot.
No matter whether you buy a car with a warranty, within a month, you'll do something to it that will void it. Just something to think about.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
09-07-2014, 12:42 AM | #10 |
Lol aight "i.e." that is
and "e.g." for example ... Guess it makes more sense now lol
369rwhp/392rwtq
09-07-2014, 09:58 AM | #11 |
Blue Streak
Drives: 2010 SIM 2SS Join Date: Dec 2012
I greatly enjoyed the build. It was the whole idea and half the fun (well sometimes not so fun..lol). Sure, ZL1 is a great car. Just hop in and have a great time. But build it, and telling people you built is, puts a larger smile on my face.
If I were to do it all over again, I'd build. This way you know what TRUELY how the car is.
2010 CAMARO 2SS SLP TVS2300 3.4 pulley, 9PSI Custom Tune, ZL1 FP, ADM FPCM, ID 850's, tr7ix plugs, CAI intake, KOOKS 1 7/8 & HFC, Magnaflow Comp catback, Pedders Xa coilovers & sway bars & sub frame bushings Mpd1 Z hood & spoiler, Vertical doors, Hurst short shifter, R1 dimpled/slotted rotors, SS brake lines, Hawk HPS Pads, Niche Apex & Nitto Invo front:20X10-275, rear:20X10.5-315, GM GFX & Satin gas cap, RS projectors, T3 bumper ports, T4 splitter, Alpine INE-W927HD, Metro dash kit
09-07-2014, 10:13 AM | #12 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
There is a lot of satisfaction with doing your own mods. I started with a new 2SS/RS. Added all the mods myself and feel good when someone asks who did the work and I can say I did. I would rather do the mods myself than buy one with some mods already done.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
09-07-2014, 10:45 AM | #13 |
Older Than Dirt
It's always good to say you did the mods yourself, but some aren't so handy with tools than others. So buying one already modded may get you what you want without having to risk tearing something up. Different strokes for different folks.
09-07-2014, 11:21 AM | #14 |
ZL1 for the drivetain IMO. if you can swing it, the mag ride, brakes, an rear end are worth it. Look at all the issues people have with axles/rears/etc on the SS. I would get the zl1 just for the rear end/etc..
Nick
Corvette Z06 -1200ish rwhp |
