Old 10-18-2015, 07:33 PM   #1
ajohnson
Drives: 2010 Camaro 1LT
Sub/amp install???
Anybody have any links to installs for sub/amp in these camaros? or better yet a video install?
I've got a 10" sub, and an amp that i've brought with me through the past two trucks and would really like to get installed into my camaro but im not very 'wire savy' so to speak. it was a lot easier to follow installs and get it sorted out on my pickups but i have no clue how to go about it with this new camaro local shops want to charge me around 200$ to install, and at that rate i'd rather just sell it.
ajohnson is offline   Reply With Quote
Old 10-18-2015, 07:52 PM   #2
poorboy10
Drives: 2010 2ss
do you have the boston system?
2010 l99 summit white w/inferno orange stripes and interior. Texas Speed longtubes, halltech cold air intake,v-max ported throttle body, MSD wires, NGK plugs, Spintech catback with x-pipe, GPI SS1 VVT camshaft.
poorboy10 is offline   Reply With Quote
Old 10-18-2015, 07:56 PM   #3
ajohnson
i dont. Stock LT, with whatever sound system that isnt boston or bose. Assuming its the basic system.
Old 10-18-2015, 07:59 PM   #4
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
we have a section just for audio should find alot in there http://www.camaro5.com/forums/forumdisplay.php?f=29
JCunningham is offline   Reply With Quote
Old 10-18-2015, 09:29 PM   #5
caverman
caverman's Avatar
Drives: '69 SS Convertible
I've got a wiring kit, amp, and a mounting board made specifically for the 5th gen for sale. I sold my car a while back and took it out before it left.
PM me if you're interested and I can give you more details.
Build Journal
Old 10-18-2015, 09:46 PM   #6
ajohnson
I've got the wiring kit, and a fitted box already. also have a sub and amp as well. thanks though.
Old 10-19-2015, 06:49 PM   #7
ajohnson
do the factory radios have rca jacks on the back? other than the sub,amp and wiring harness for the sub/amp is there anything else i need for install?
Old 10-19-2015, 06:56 PM   #8
Demon War Horse
War Horse Pilot
Demon War Horse's Avatar
Drives: 2017 NFG 1SS 1LE
If the deck does not have RCA outputs, you ill need a line out converter. This will tap into say the rear speakers to give you RCA lines to run to the amp.
COTW 09/07/2015 - 2014 AGM 2SS/RS - RIP 6/01/17
2017 Nightfall Gray Metallic 1SS 1LE Born 5/17/17 - Click Sig Pic below for for Demon War Horse 02 Build Thread
SigPic by Hazman
Demon War Horse is offline   Reply With Quote
Old 10-19-2015, 08:36 PM   #9
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
http://www.camaro5.com/forums/showthread.php?t=191938
You can use that if you don't want to splice into the wires at the rear speakers. If you don't mind splicing into them just get the signal from the rears.
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 10-19-2015, 08:42 PM   #10
760bowtie
760bowtie's Avatar
http://www.camaro5.com/forums/showthread.php?t=213330
A little more work but this one will work better if you're going to run separate amps (or 5 channel) and upgrade the inside speakers.
Old 10-19-2015, 10:10 PM   #11
ajohnson
I think im just going to wire into the rear speakers and then hook power into the fuse box in the truck. seems to be the simplest way.
Old 10-19-2015, 10:37 PM   #12
760bowtie
760bowtie's Avatar
I used an add-a-circuit to tap into a fuse at the fuse panel on the driver's side. I think it was fuse #18
Old 10-19-2015, 10:41 PM   #13
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
i installed everything myself, if you need help let me know i can kinda help guide you lol! .
for my first time, i used Sub-Thump box and Sub-Thump wire plug in kit. the plug kit made it so no splicing needed.
Hellfighter is offline   Reply With Quote
Old 10-20-2015, 01:32 PM   #14
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
You must connect the amp's power lead directly to the battery. The factory fuse block does not carry enough current to run an aftermarket amp.
jeffa is offline   Reply With Quote
