05-10-2011, 07:33 AM | #1 |
Drives: Awaiting 2014 C7 Join Date: Sep 2009
Question for guys running pfadt sway
I have had my bars on for about 4000 miles and everything is great. How often do you grease the bushings and what are you using?
Awaiting 2014 C7
05-10-2011, 10:54 AM | #2 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Glad to hear that everything is working well!
There are Zerk fittings on the sway bar brackets for easy re lubrication. Be sure to use a high quality marine grade grease, typically available at online retailers or local marine shops. The super tacky marine grade grease we provide with the kits is what we find works really well at keeping Polyurethane from making noise over time. I would give them a quick visual every time you change your oil, but re lubrication should be necessary only every 10,000 miles, or if begin to make a little noise. Go out there and enjoy your car! Weather has been awful this spring in Utah, we sure could use a little California sunshine. -- Jarrett |
Similar Threads | ||||
Save $$$ with Pfadt suspension packages from Apex Motorsports | Apex Motorsports | Suspension / Chassis / Brakes | 75 | 12-13-2010 09:29 AM |
Pfadt sway bars and adjustable links set up? | baranowski | Suspension / Brakes / Chassis | 13 | 08-30-2010 05:47 PM |
Pfadt Adjustable Race Sway Bars - the only choice for competition | PfadtRacing | Suspension / Brakes / Chassis | 22 | 06-28-2010 01:20 PM |
Pfadt Race Engineering Balance Sway Bar package | PfadtRacing | Wheels and Tires Talk Sponsored by The Tire Rack | 0 | 08-17-2009 01:41 PM |
