10-02-2015, 12:14 AM | #1 |
Drives: 2010 camaro ss Join Date: Sep 2015
LOOKING FOR A GOOD SCRATCH-FREE CAR COVER.ANY RECOMANDATIONS?
My camaro is black and i wash it and wax very often because i park it in the backyard so gets dirty really fast.im thinking to buy a car cover that wont scratch my car since its black and scratches are really noticeable.what do you guys recomend
10-02-2015, 12:25 AM | #2 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
All car covers will scratch if there is any dirt present.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
10-02-2015, 12:46 AM | #3 |
Drives: 2SS/RS Join Date: Sep 2008
Scratch free and car cover are two things that don't go together. As mentioned above, all car covers will eventually cause scratches in the paint and they should never be used outdoors. Dirt and other particles will work their way up and underneath the car cover rubbing on the paint and every time the wind blows the cover will beat on the car, slowly damaging the paint. Even if you keep the car 100% clean in a perfectly clean environment with no air circulating, the nose, rear, and roof of the car will slowly show signs of damage simply just from removing and installing the car cover. Car covers really are only intended for one purpose, long term storage indoors.
10-02-2015, 12:54 AM | #4 |
thanks for the info guys..never mind on the car cover lol...ill just keep taking care of my ride
10-02-2015, 01:54 AM | #5 |
I have a black Camaro that stays clean for about 30 seconds. But in those 30 seconds I'm like "damn! That's a sexy car"
I sealed my garage off best I could and covered the ceiling with a sheet of plastic. I've tried everything to keep it clean. The less you touch the paint, the less scratches you'll have. Keep it waxed and before you wash it, use an air compressor to get as much dust off before you start to wash. Never wash or dry in circular motions, just lightly in one direction. |
10-02-2015, 08:46 AM | #6 |
Drives: 2012 1LT Drop Top Join Date: Oct 2013
Yep, indoors only!
10-02-2015, 09:17 AM | #7 |
High-tech Redneck
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8 Join Date: Nov 2010
I came in here to say the exact same thing....and now I say it. ^^^Ditto^^^
I was naive and did it once way back. I learned. I like the inside cover to be the softest thing you can possibly get and NEVER EVER cover your car unless it is totally as clean as you can get it.
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning. |
10-02-2015, 09:23 AM | #8 |
EbonyCamaro
I have the gm cover very nice and I have a black car. Light scratches in clear coat are naturally going to happen all cars have them. But they are amplified on black. Get a orbital polisher and do a correction on clear coat every 18 months or so.
10-02-2015, 09:36 AM | #9 |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
What does a cover do for a car kept inside I could never fiigure that out? My car is parked in the garage during the winter months but it isnt covered... I back it out and wash it when she is set free!
10-02-2015, 09:42 AM | #10 |
High-tech Redneck
Usually it is to avoid that step. Wash when you park, and she is ready when you are...not ready AFTER you spend an hour washing.
10-02-2015, 10:05 AM | #11 |
Gotcha! I just wasn't sure I thought it protected the car in some way while indoors but couldn't figure what that would be. So it wouldn't do much in my situation really.
10-02-2015, 10:08 AM | #12 |
Drives: 2013 VR 2SS RS Join Date: Sep 2012
I like the Covercraft dustop cover I bought. Wipe the car down with some water less wash, put on the cover, and its clean for Spring time fun.
10-02-2015, 10:09 AM | #13 |
It depends on where you live and if you have potential dust problems even with the car sitting inside.
10-02-2015, 10:34 AM | #14 | |
Oldbie that nobody knows
Dirt won't find it's way up the finish of a car with a cover that is custom fit. When I take my Weathershield HD off, the car pretty much looks exactly like how it did when I put it on, even after weeks of sitting. For those of us who don't have a garage but want a finish that looks as though we did, a good quality outdoor car cover is the ONLY option. It's just that you must always make sure you're putting it on a clean car. You CANNOT beat the elements, I don't care how often you wax. |
