Old 10-20-2016, 08:14 AM   #1
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Anyone running 305/35/20s all around / front
Will 305/35/20 tires:
- fit on the front 10" rim
- fit in the front wheel well
- rub in the front wheel well
- reduce the quick turning nature vs 285/35/20
Sent from my iPad using Tapatalk Pro
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 10-20-2016, 11:47 AM   #2
PapaKlutch
PapaKlutch's Avatar
Drives: 2015 Camaro SS/1LE
Bruce Hopkins has run them. Check him out on this thread:
http://www.camaro5.com/forums/showth...92#post8982692
2015 2SS/1LE/RECARO/NPP/RS/NAV
PapaKlutch is offline   Reply With Quote
Old 10-21-2016, 12:08 AM   #3
CrystalRedTintcoat
Thank you. I found some online Tire/Rim calculators. Check them out on the link.
Old 10-21-2016, 09:08 PM   #4
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
I am but on 10.5 wheels with custom offsets. I also have coilovers, caster bolts and caster camber plates to get the proper alignment and clearance.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
