#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 09-15-2018, 01:40 PM   #1
12camlt
Drives: 2016 2SS
Hood not even?
Just purchased a 2016 2SS with 10,000 Miles.
Does my hood alignment look off?
12camlt is offline   Reply With Quote
Old 09-15-2018, 01:54 PM   #2
Deakins
Drives: 2017 2ss, m6
I really cant tell with the round roll of tape on it.
Deakins is offline   Reply With Quote
Old 09-15-2018, 02:04 PM   #3
12camlt
Drives: 2016 2SS
Tried to give a perspective with the tape. Here’s other shots.
Old 09-15-2018, 02:21 PM   #4
chris227
chris227's Avatar
Drives: 2020 Camaro 2SS
Simple fix, Adjust it. Fairly common issue.
Just take your time and make small adjustments till it's correct.
chris227 is offline   Reply With Quote
Old 09-15-2018, 03:44 PM   #5
Xeno13
Xeno13's Avatar
Drives: 2018 ZL1 1LE / Nightfall Grey
I had a issue where the hood would not close when you dropped it for about a foot from close - it was the little round hood stoppers, I think they just turn by hand and you can adjust the height of the hood like you want ( I think)
Ps how do you add images to the darn forum - I have a image for the, but I just get a URL option to add it 0 how can you upload one?
Xeno13 is offline   Reply With Quote
Old 09-15-2018, 06:04 PM   #6
GroundhogSS
GroundhogSS's Avatar
Drives: '17 2SS convertible'20 Yukon Denali
Sometimes when you adjust up the hood stoppers, the hood won't latch. I had to raise the latch mechanism a bit to get it to latch and be even.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
GroundhogSS is offline   Reply With Quote
Old 09-15-2018, 06:45 PM   #7
CruzySS
CruzySS's Avatar
Drives: 2016 Camaro 2ss
My trunk was not aligned. There are two screws to adjust it up and down. I'm assuming there is something like that for the hood
CruzySS is offline   Reply With Quote
Old 09-15-2018, 07:30 PM   #8
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
That hood edge along the front bumper cover and both front fenders is easily adjustable. There are adjustable stops and the enclosure plate when you open the hood is adjustable also. A good body guy can fix that in 15 minutes
lt4camaro is offline   Reply With Quote
Old 09-16-2018, 03:13 AM   #9
MR2620
MR2620's Avatar
Drives: 2017 ZL1 - Hyper Blue
There are 2 torx head bolts in the radiator support/cover, 1 on either side of the hood latch. Those adjust the height of the front bumper cover. I had the same issue and some others on here have as well. My guess is that'll fix your problem. Check this write up for details and pictures.
https://sandyblogs.com/techlink/?p=5622
Sent from my Pixel 2 XL using Tapatalk
MR2620 is offline   Reply With Quote
Old 09-16-2018, 07:47 AM   #10
Number 3
Hail to the King baby!
Number 3's Avatar
Yes, the alignment is off. I'm not sure what the actual spec is but it should be around +/- 1 or 1.5 mm for general body panel fits and you look way over that.
First of all, is the car still under warranty? If so have someone who knows what they are doing make the adjustment.
If not, you've been provided some good information on making the adjustment yourself.
Good luck!
Old 09-16-2018, 09:32 AM   #11
18LTLoveIt
18LTLoveIt's Avatar
Drives: 2018 Hyper Blue LT RS
That happened on my 2013 too. Good to know it's adjustable.
18LTLoveIt is offline   Reply With Quote
