#Camaro6
Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro 1LE
AWE Tuning
Old 12-10-2021, 07:02 PM   #1
10mm
Drives: My wife nuts...
Any special methods for cleaning/ detailing the 1LE hood?
Tread lightly when cleaning etc ??
10mm is offline   Reply With Quote
Old 12-10-2021, 07:52 PM   #2
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Foam, rinse off dirt, soap, rinse, soap, wash, dry. It's pretty durable stuff.
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs.
http://www.motorsportsne.com/
Vtor_ZL1 is offline   Reply With Quote
Old 12-11-2021, 12:55 AM   #3
shippingguy
Drives: 2024 Black ZL1, M6
On my ‘22 I use a duster then a damp micro fiber towel with just water. Follow up with Chemical Guys Matte Detail spray. No issues. Did the same on my 2014 and that wrap looked new the day I sold it.
shippingguy is offline   Reply With Quote
Old 12-11-2021, 08:27 AM   #4
hotlap
hotlap's Avatar
Drives: 20 1LE 2SS M6 Rally Green
I bucket wash and dry with a Master Blaster. I then wipe the hood, mirrors and rear spoiler with Meticulous Matte.
My Hot Wheels matte stripes would get temporary water spots when left to dry after a rain. Wiping with Meticulous Matte eliminated that problem.
A Master Blaster is a must given all the crevices in the grill design.
https://www.chemicalguys.com/meticul...-detailer.html
https://www.chemicalguys.com/metro-m...iAAEgJbtPD_BwE
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.”
Ronald Reagan -
hotlap is offline   Reply With Quote
Old 12-11-2021, 12:03 PM   #5
Ruby13
Ruby13's Avatar
Drives: 2019 2SS/1LE Shadow Grey
I use Wizards Matte Finish detailer.
Ruby13 is offline   Reply With Quote
Old 12-12-2021, 04:48 AM   #6
s346k
s346k's Avatar
Drives: like an old lady
soap & water only
best thing i did for the appearance of the hood was replace the factory installed wrap with 3m satin black.
i've tried every "matte" detailer available, i did not find one that didn't have its own set of issues. soap & water only now with the aftermarket wrap always looks good.
2016+ camaro: everyone’s first car
s346k is offline   Reply With Quote
Old 12-12-2021, 05:23 PM   #7
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
on my 13 1LE hood, Ive always used soap and water. If I had spots Id use detail spray with a microfiber. If the spots still didnt come out I used APC with a micro fiber.
I had someone put a coffee cake on my hood while it was raining and had cake and goop on my hood left over. It came out with those methods.
Maintenance wise, every 6 months or so Ill put Adams VRT on a microfiber applicator and then wipe it down with a microfiber to get it even.
Just detailed my 22 1LE and hit it with some APC because it had some stuff on it from transport and then hit it with VRT.
Old 12-25-2021, 02:51 PM   #8
CACer55
Drives: 2021 1SS-1LE
I treat mine like the rest of the car. But then I took the wrap off!
CACer55 is offline   Reply With Quote
Old 12-25-2021, 04:11 PM   #9
Warrior102
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
Same here, the hood has some interesting lines without the dull wrap and looks better IMHO, YMMV. If I was ever to replace it it would be in satin black.
Warrior102 is offline   Reply With Quote
Old 12-26-2021, 09:59 AM   #10
CACer55
Exactly! Especially on the darker colors! Mine is Shadow Gray.
Old 12-26-2021, 11:38 AM   #11
JSH
JSH's Avatar
Drives: '20 ZLE
I spray wash my car and wipe it off with towels. Occasionally apply cleaning wax to rear areas to get rid of fuel haze. Vacuum once a month, maybe. That's it.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
JSH is offline   Reply With Quote
Old 12-27-2021, 02:22 PM   #12
Coded4SS
Drives: 2020 1SS 1le
wash it, then use mckees matte detailer and sealant. will look absolute tits
Coded4SS is offline   Reply With Quote
Old 12-27-2021, 06:22 PM   #13
Husker67
Husker67's Avatar
Drives: '22 Camaro 2SS 1LE Wild Cherry
Was it a DIY project? Or did you have a shop take it off? If you took it off, was it hard to get off??
Thanks.......
Husker67 is offline   Reply With Quote
Old 12-28-2021, 08:46 AM   #14
Wyzz Kydd
Banned
Drives: 2018 Camaro SS1 1LE
I've waxed mine a few times, which made it more gloss than matte.
Wyzz Kydd is offline   Reply With Quote
