#Camaro6
Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro 1LE
Old 04-29-2023, 03:12 PM   #1
pontiaco1
Drives: 2018 1LE
1LE Quarter mile kings come in
Alright guys ,so I have a 2018 cmaro 1LE with full bolt ons and with 13k miles on the clock.
Specs
Lt2 intake 95tb
2in full length headers with full 3 exhaust and x pipe and into axle back AWE touring mufflers.
160 thermostat
Roto fab CAI
Msd wires
And E 85
M6
And remote tune tuned by GPI
So I want to take it to the track for 1/4
mile pass. The car feels pretty healthy on the street, but I want to know what lauching techniques you guys have luck with, right now I can only use launch control so it won't spin the tires.
Tires are stock 305 50 20 SC3s.
I been to the track for 20 years but never on a 6speed manual car.
Old guy here lol
Thanks
pontiaco1 is offline   Reply With Quote
Old 04-30-2023, 09:35 PM   #2
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Lol
Everything happens for a reason, except when it doesn't, but even then, you can, in hindsight, fabricate a reason that satisfies your belief system.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 05-03-2023, 11:56 AM   #3
KarFan
KarFan's Avatar
Drives: 2023 SGM Camaro 2SS 1LE 6M
Might want to roll over to the Drag racing section as you'll have more of a drag racing audience.
Be prepared for the "why drag a 1LE" and "Just put ET streets on it and drop the clutch" but there should be some better info there for you.
KarFan is offline   Reply With Quote
Old 05-03-2023, 12:12 PM   #4
6spdhyperblue
Drives: 6th gen
Really needs a et street r on a 17” wheel in the back.
FBO on a 26” tire should be 11 flat and 10s in good air with skinnies, rear seat out
Hold 4k then blip up to 5,500 and slip the clutch as quickly as possible with out shocking the drivetrain. Add throttle slowly. It’s not a sidestep or burning the clutch.
When the clutch is out, plant your right foot the rest of the way.
I went twice without a tire and i couldn’t get a single good pass in
‘22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28” dragpack - 11.68@122
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
6spdhyperblue is offline   Reply With Quote
Old 05-09-2023, 01:34 PM   #5
pontiaco1
Drives: 2018 1LE
Thanks guys, ran a 12.55 with no traction at all, spinning on all 1 2nd and 3rd gears, leaving at 3krpm, shit load of wheel hop
Old 05-09-2023, 08:32 PM   #6
6spdhyperblue
Drives: 6th gen
I noticed that as well moving to the white car, that’s why I never got a clean pass.
My 16 ss never once did it.
I got a 305 et street r on a 17x9.5 in the back before I did any harm. Now it’s all good
Old 05-10-2023, 11:54 AM   #7
Melon
Melon's Avatar
Drives: '23 1LE, '18 Canyon, '87 325i
I should do more 1/4mi runs. It's not why I bought the car, but going to a test-n-tune night for like $50 is a lot of fun.
Melon is offline   Reply With Quote
Old 05-29-2023, 08:28 PM   #8
pontiaco1
Drives: 2018 1LE
so you didn't get no more wheek hoop after the drag radials?
Old 05-29-2023, 08:58 PM   #9
6spdhyperblue
Drives: 6th gen
No wheel hop after drag radials
Old 06-04-2023, 08:25 AM   #10
s346k
s346k's Avatar
Drives: like an old lady
as mentioned, ditch the factory wheel for a drag wheel. i had pretty good luck on a 26" mt et street r. i think i could've gotten the car down a couple more tenths if i had more opportunities. the car ran good but was heavy and i had 0 experience launching it at the track. i had 1 decent launch of 3 passes. the mph was there every time regardless of 60' though.
this was during the "everything shortage" so no track prep. i left like it was on the street and surprisingly it dead hooked, bogged and almost died. i never went back to the track.
2016+ camaro: everyone’s first car
s346k is offline   Reply With Quote
Old 06-04-2023, 08:41 AM   #11
JSH
JSH's Avatar
Drives: '20 ZLE
Just going by your mods, you've got less than 600rwhp, so you should be able to put MT on it and get it to go down the track.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
JSH is offline   Reply With Quote
Old 06-10-2023, 09:29 PM   #12
pontiaco1
Drives: 2018 1LE
I'm just concern about the violent wheel hoop and been serching and trying to understang how drag radials will make my hooping issues go away, must people say id the lower control arms and cradle bushings so I was going to change everything at once!
Old 06-11-2023, 09:21 PM   #13
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Tires have a lot to do with wheel hop.
A tire that works great in the summer may hop bad in cooler weather.
'18 1SS 1LE Black, PDR
Boost Creep is offline   Reply With Quote
