05-13-2011, 11:33 AM | #1 |
Drives: Camaro 2SS Join Date: Jan 2010
Help! Need front camber!!!
Just got my car back from mechanic! I got BMR trailing arms, toe rods, 1" inch lowering springs, sways and all the bushings installed! I was told that I need a camber kit for 2 degrees of camber??? My front left is at -2.4 and my right is -3.1! Any suggestions? I am in no way a suspension expert! LOL!
05-13-2011, 12:20 PM | #2 |
Does the numbers even sound right? Meaning, does my mechanic even know what he's doing? LOL
05-13-2011, 10:18 PM | #3 |
TTT
05-13-2011, 10:22 PM | #4 |
R6P Marketing Lab Rat
Drives: sometimes Join Date: Feb 2009
The lowering springs have effected your camber and toe.
There are bolts that go into the the top hole of the strut that will get you the 2 degrees and get you in spec. |
05-13-2011, 10:24 PM | #5 |
Are you telling me I can get the 2 degrees without a camber kit?
05-13-2011, 10:27 PM | #6 |
yup.
Here's a link for an example. These are 3 degree bolts and will definitely provide a solution. http://www.spohn.net/shop/2010-Chevr...ontiac-G8.html |
05-13-2011, 10:54 PM | #7 |
Thank you very much PoleCat for the help!
05-13-2011, 11:02 PM | #8 |
You are welcome anytime. Not a problem.
Let us know how it turns out. |
05-14-2011, 07:13 AM | #9 |
Drives: 2014 Z28 camaro Join Date: Sep 2009
Find a alignment shop that knows,there should be more than enough adjustment to get the camber within specs.
05-15-2011, 08:47 PM | #10 |
Drives: 2010 SS with WAY TOO MANY MODS Join Date: Sep 2010
We've been aligning these cars for street AND track use and haven't run into a car yet we can't get within spec. Now caster..... That's another story! ;-)
05-16-2011, 10:19 AM | #11 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
-3 degrees seems like a pretty extreme camber gain out of only a 1" drop. There should be plenty of adjustment capabilities the stock camber bolts to account for a slight drop. Here is a link to our alignment specs, we've found they work very well for these cars. The Performance Street alignment should be possible with the stock hardware on a car that hasn't been damaged in another way.
http://www.pfadtracing.com/blog/wp-c...-alignment.pdf |
05-16-2011, 02:04 PM | #12 |
So... If I buy the $40 camber bolts, will these solve my problem?
05-16-2011, 02:14 PM | #13 | |
Drives: Camaro Join Date: Jun 2009
I forget the size but its a metric bolt that is required, you technically only need one for the alignment, and any decent hardware store or alignment shop should have them. I'll see if i can find out what the size is. Thanks Mike Haddad |
Similar Threads | ||||
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
Poll -- Camaro vs Mustang Supercar Shootout | JusticePete | Suspension / Brakes / Chassis | 105 | 10-09-2013 02:18 PM |
Setting up an IRS/Drivetrain for Drag Racing | Kyle2k | Suspension / Brakes / Chassis | 44 | 06-05-2010 09:17 PM |
