09-02-2023, 06:36 PM | #1 |
Drives: 2023 Sharkskin ZL1 M6 Join Date: Oct 2009
GM 12609623 (angled) Oil Filler Tube and its notch
Saw this thing
on a parts list under https://youtu.be/1IkFYjPDrtY?si=-sERuyZhjs7gvrOk Linked with the funnel I think it would be very nice. However, this text "GM Angled Oil Fill Adapter: https://amzn.to/3zKJ7Az This adapter has a revision. It has a tab that needs to be removed before using, otherwise it can lock into the valve cover. If that happens, you can remove it by using a pick tool to lift the tab. This adapter is NOT meant to be permanently installed in the Camaro." I think this locking mechanism is meant for semi-permanent installation, i.e. with valve cover removal to remove. It mentions a pick to move the tab but I don't have something that can get at that angle. Wondering if anyone used/uses this, and has broken off the tab, and how they went about it/smoothing it out/etc. I realize I'm veering into the range of 'why bother' - the rest of the funnel setup described in the text can probably flow even at an angle. |
09-03-2023, 06:44 AM | #2 |
Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
I have same adapter and I trimmed off the square edge of the locking tab to prevent it from engaging. I Just used a Olfa razor blade.
09-03-2023, 09:00 AM | #3 | |
Thanks Matt |
09-03-2023, 10:10 AM | #4 |
Feathered back about 1/4”
09-21-2023, 01:59 PM | #5 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Why does the tab need to be ground off?
There is no need to turn the adapter 90 deg to get it to lock, if you do the opening is sideways (pointing to the back of the car). You only need to push it into the OE filler on the valve cover and then connect the Motive MX2302 funnel. https://www.motivxtools.com/products...2&_ss=e&_v=1.0 Did I miss something?
09-21-2023, 03:24 PM | #6 | |
09-22-2023, 12:03 PM | #7 |
Geoff
I get ya. It is good being safe
10-04-2023, 03:06 PM | #8 |
Drives: 2022 Camaro 1SS 1LE Join Date: Nov 2021
During my last oil change, I just cut one of the quart bottles on an angle and used that as a funnel.
2022 Camaro 1SS 1LE 6-speed
