07-26-2013, 02:43 PM | #1 |
Drives: Black 2ss Join Date: Jul 2011
Camaro problem, missing
Hi, My Camaro ss has 14282 miles on it.
Put exhaust on a couple of months ago, ported throttle body, and it ran fine... Couple of weeks ago when gainig speed I started hesitating... like it was missing or something. I work 14-7 schedule and stay out of town for the 14 so didn't have time to mess with it.. today I decided to drive it and the hesitation got worse and worse to the point where I thought it was going to die in first gear. put slp headers/exhaust on a few months ago and it ran fine until this.. the 3 codes that are showing are all o2 sensors according to the chevy dealer. what should I do? replace the o2 sensors? Take it to someone and have it tuned? Or could it be a worse problem? also... the 02 codes have been showing since I got the exhaust |
07-26-2013, 03:44 PM | #2 |
Drives: 2010 Camaro SS, 2005 CTS-V Join Date: Mar 2013
Unfortunately your car is a picky one. With headers its hit and miss with them running fine. The rear o2 sensors will freak out and cause issues. You probably just need a tune and you'll be fine. Plus you will getthe full potential of the headers!
07-26-2013, 03:46 PM | #3 |
Drives: '69 SS Convertible Join Date: May 2009
Did you take the spark plugs out when you installed your headers? If not my guess is it's going to be a cracked spark plug.
I don't think the O2 sensor CEL is going to make the car run bad. I guess if the rear one is bad or something it's possible that it's reading the O2 incorrectly and either giving or taking fuel and spark. Probably going to a tuner wouldn't be a bad idea.
Build Journal |
07-26-2013, 03:53 PM | #4 |
Fourmz
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28 Join Date: Sep 2009
^This^
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
07-26-2013, 06:01 PM | #5 | |
Thanks everyone |
07-26-2013, 06:08 PM | #6 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Since you have had the O2 codes since the exhaust installation I think you may have been running too rich and may have fouled out one or more spark plugs. But just a guess, pull them and look.
The Bird is the word! |
07-27-2013, 01:32 PM | #7 |
Drives: 2014 CTS-V- totalled/ 45TH ss- SOLD Join Date: May 2013
Rear O2 only tell computer your cats are working. Front two do fuel management. Either you can try spacers on the front 02 censors, or check your spark plugs as another mentioned. If you tune out your o2 sensors... no more problems unless it is indeed your plugs.
2014 CTS-V... with some go-fast bits coming
07-27-2013, 06:20 PM | #8 |
Helping Build America
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD Join Date: Aug 2008
When my trunions went bad the computer showed a code for random misfire due to plugs fouling. If plugs were the issue, wouldn't he be getting a misfire code?
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
07-28-2013, 10:15 AM | #9 |
Do you have a catch can? I had my drain plug on my catch can loosen up and cause a small vacuum leak. That started throwing codes from my O2 sensors that they were running lean.
Build Journal |
Thread Tools | |
