05-01-2011, 02:27 PM | #1 |
Drives: '10 Camaro, IBM 2LT/RS Join Date: Jun 2009
Strange thing just happened.....
I just stepped outside to move the Camaro to let another car out of the driveway and something strange happened. With this car I've gotten into the habit of turning the key and letting it go, since you don't have to keep the key turned the whole time it's cranking (I know there's a name for this feature, just can't remember it at the moment). So I do that as normal and as soon as I released the key it stopped cranking. After a few seconds of confusion I turned it again and released. Same thing. For the next attempt I kept the key turned until it started and everything worked fine, car started up and I was able to back it out and back in. Fearing that there was something wrong with the car after I pulled it back in I tried to start it with a quick turn and release as normal and it continued to crank as it should and started with no problems.....
Has anyone else had this happen to them before? Was this some odd electronic fluke caused by the positioning of Venus in relation to Neptune and the Sun? Should I be worried about this even if it never happens again......? Thanks in advance for any help...
[Insert obligatory car/order info below]
2LT RS; Imperial Blue Metallic w/ Silver Rally Stripes; Gray Leather Interior; Automatic; Exterior Painted Interior Trim Panels; Blue LED Footwell Lighting; Dash ABL; DRL Halos Ordered - 1/16/10 at Weber Chevrolet in Granite City, IL (Excellent experience; Thanks John!) Produced - 2/24/10 In the driveway - 3/4/10 Total time order to delivery - 47 days |
05-01-2011, 02:33 PM | #2 |
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS ) Join Date: Nov 2009
Obviously there's a hitch in the get-along which is consummately allied to the angle of the dangle. Say the complete rosary thrice whilst throttling the life outa' the mother-in-law.
You'll see, everything will be hunky-dory. |
05-01-2011, 02:36 PM | #3 |
Drives: '10 Malibu, '97 'Stang Convertible Join Date: Mar 2011
05-01-2011, 02:37 PM | #4 |
It has happened to me multiple times. Car is fine. Sometimes it just requires being held.
05-01-2011, 02:42 PM | #5 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
05-01-2011, 02:50 PM | #6 | ||
05-01-2011, 02:54 PM | #7 |
It has happened to me as well. The way I understand it is if the computer just senses a "flash" of current from a quick key turn it thinks there is something wrong and requires the key to be held until start up. Mine did it once and the DIC said that the stability track needed service. Next time I started everything was ok. Others on here may have a better technical explanation but that is mine. Remember it is all controlled by a computer.
05-01-2011, 03:05 PM | #8 |
EMERALD COAST CAMAROS
Drives: 2lt summit white dk gray int Join Date: Jul 2009
pay no attention to the man behind the curtain!
Big Bertha!
2010 summit white 2Lt cgm rally stripes,hot pink pin stripes,doug thorley shorties,pink bowties,led side markers,sequetial led tail lights,NLP spoiler,magnaflow axel back exhaust, AIRAID CAI(soon to be Vararam) |
05-01-2011, 03:57 PM | #9 |
QuandoOmniFlunkusMoritati
Drives: '06 Magnum R/T -to be '01 Camaro SS Join Date: May 2010
Is this line from Pirates of the Caribean? It just really sounds like a Jack Sparrow ramble.
05-01-2011, 04:01 PM | #10 |
I spoke to Mr. Goodwrench about this issue. He said there will be a TSB for the ocillator valve sticking.
05-01-2011, 04:17 PM | #11 |
Drives: Really Slow Join Date: Apr 2010
i'm not 100% about this, but i think it also doesn't work if your wheels are turned.
05-01-2011, 06:12 PM | #12 |
Chief Many Camaros
Drives: A paid off Camaro!!! Join Date: Mar 2009
It has happened to me also, usually just cause I have not kept the clutch fully depressed.
504hp/478tq Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac |
05-01-2011, 06:24 PM | #13 |
It did happen to me , well no to me but to the other car [2009 express cargo van ] once and that was it
05-01-2011, 06:25 PM | #14 |
el Ruco
Similar Threads | ||||
Strange noise coming from behind the dashboard on the passenger side | gatorsrule | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 47 | 04-14-2021 11:42 AM |
IT HAPPENED TO ME!! | BoostedX2 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 50 | 09-30-2010 06:14 PM |
Is the same thing happening in your town?? | tmac1granger33 | 5th Gen Camaro SS LS LT General Discussions | 64 | 09-27-2010 12:22 AM |
DFW guys whatever happened to the......... | Jekyll-N-Hyde | USA - Texas | 8 | 06-11-2010 07:49 AM |
GMHTP April 08 - A Thing Of Beauty | TAG UR IT | Camaro Photos | Spyshots | Video | Media Gallery | 7 | 02-28-2008 11:53 AM |
