12-03-2013, 03:36 PM | #1 |
Drives: 2010 camaro ss ( LS3 ) Join Date: Apr 2011
Stock LS3 boost limit? best pulley for Magnuson?
Hey guys
I've finally bought a supercharger for my 2010 Camaro M6 :headband: Long tube header + 2.5" cat-back + ZL1 feul pump + wideband installed I bought the Magnuson kit which comes with 3.8 pulley (6 psi) This supercharger will make about 125 HP with this pulley compared to 150+ HP with the SLP supercharger! My question is (How far should I go with the boost to gain 150-160 HP? What's the best choice for the pulley?) waiting for your replies Thanks all Last edited by T-r3x; 12-03-2013 at 09:38 PM. Reason: Adding all the mods |
12-03-2013, 03:56 PM | #2 |
You need to list all your current MODs first off.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
12-03-2013, 04:39 PM | #3 |
~800-820rwhp on a blower and ~850-900rwhp on turbos has been done and stayed together. All in the tune/octane.
Nick
Corvette Z06 -1200ish rwhp |
12-03-2013, 05:46 PM | #4 |
A lot of people are running the 3.6 pulley on the stock bottom end.
12-03-2013, 05:48 PM | #5 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
One miiiiiillllliiiioooon psi.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
12-03-2013, 06:31 PM | #6 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Boost pressure is nothing compared to combustion pressure. The more efficient the engine is the less boost it will take to make horsepower. I lost a headgasket and the motor internals due to hydolock at speed at 805 hp on a stock LSA block, I was on a road racing course and pushing the car. I think about 780 is safe more than that is dangerous. My opinion but based on over 10 grand worth of experience.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
12-03-2013, 09:30 PM | #7 |
12-03-2013, 09:35 PM | #8 |
Blessed
Drives: 2013 Sonic RS MT Join Date: Dec 2007
On the stock fuel system, I wouldn't go above 7 PSI.
That seems to be the point where guys start running out of fuel. once you add a high flow pump like ZL1/1LE pump. you can go a little north of that. But most Daily drivers stay below the 600 at the tires on the stock bottom end. Good luck!
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
12-03-2013, 09:36 PM | #9 |
12-03-2013, 09:39 PM | #10 | |
12-03-2013, 09:41 PM | #11 | |
12-03-2013, 09:43 PM | #12 |
Drives: 2010 Camaro SS/RS Join Date: Oct 2009
with your current setup and a 3.6 pulley, you should be at about 540-550 rwhp on a 93 octane tune
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
12-03-2013, 09:43 PM | #13 |
Blessed
Nice! then I wouldn't chase a rwhp number... I'd let the tune tell you what you need to get more power...
any tuner can make a 1000 to the wheels on the stock bottom end... once.... I'd get the car dialed in on a safe tune with what you have... then work with your tuner to figure out what you need to add to safely get to the number you want.... let the tune lead the way.....
12-03-2013, 10:03 PM | #14 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
Power is just a number determined by a machine. Every machine differs, as does every blower setup. I'm going for more power now, but it has no bearing on how fast I can get the car up to. A car making less power on a Maggie can out perform my car with a centri depending on the run. So, really the question is, what goals are you trying to accomplish?
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
