12-04-2013, 01:24 PM | #1 |
Drives: 2010 camaro ss ( LS3 ) Join Date: Apr 2011
Can I install CTS-V LSA HIGH-VOLUME FUEL PUMP??
Hey guys
I was wondering if I can install CTS-V LSA HIGH-VOLUME FUEL PUMP on my 2010 camaro LS3 ((((directly)))) PART #19207950 I heard that it's the best choice if you're looking for 600+ rwhp The ZL1 fuel pump can't handle that much power, can it? Last edited by T-r3x; 12-04-2013 at 01:38 PM. |
12-04-2013, 01:35 PM | #2 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
The Livernois is an adapted CTS-V pump I've been told but no proof. If it is, the fittings are different than the CTS-V pump as they modify them for the pickup tube. Livernois claims 8-900 hp on theirs. It's what I currently have on E85 and I'm losing pressure north of 600 whp, but remember E85 requires ~30% more fuel.
Waiting for a Squash returnless system here. The ZL-1 pump + ADM FP controller might get it for you with the proper programming. Still wasn't enough pump for me on corn.
12-04-2013, 01:41 PM | #3 | |
12-04-2013, 02:23 PM | #4 | |
Ted.
www.jannettyracing.com
12-04-2013, 02:27 PM | #5 |
The Zl1 pump and adm module is good for low-mid 600s on fi setups.
12-04-2013, 06:19 PM | #6 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
12-04-2013, 09:57 PM | #7 |
12-04-2013, 09:58 PM | #8 |
12-05-2013, 07:49 AM | #9 |
The GM ZL-1 fuel pump is very reasonable to purchase but only works correctly with the ADM Fuel pump control module and Custom tuning
All of which I can provide. This combination has proven to be very reliable and easy to install to 650 RWHP on an LS3 or 600 RWHP on a L99 Anything above these power levels move directly to the LPE twin pump system. Ted.
12-05-2013, 08:26 AM | #10 |
What's the limit with the LPE twin?
12-05-2013, 08:35 AM | #11 |
Around 850 Wheel on an LS3 800 on an L99 but it varies on Fuel demand and AFR.
12-05-2013, 08:38 AM | #12 |
That's what I thought, thanks.
12-05-2013, 09:33 AM | #13 |
Thanks all
