03-15-2014, 09:30 AM | #1 |
Drives: 2010 camaro ss ( LS3 ) Join Date: Apr 2011
I make 535 rwhp and my target is 650 rwhp, what to add?
Hey guys!
I'm planning to reach my next goal! 650 rwhp! Currently my ls3 makes 535 rwhp with these mods: Magnuson supercharger (stock pulley) 1-7/8 American Racing Headers (long) + off road pipes CAI intake ZL1 fuel pump Borla s-type 2.5" cat-back McLeod RST clutch What is the best mods that will let me reach my goal saaaaaaaafely with almost 0 issues? Should I add a cam or a stroker or what and what's the best brand to buy from? Should I upgrade the entire fuel system including injectors or do you think that BAP will be enough? Should I upgrade the cylinder heads? I know that's a lot of questions but I need your experience Thanks all! |
03-15-2014, 10:04 AM | #2 |
Drives: 1973 Camaro Join Date: Jul 2011
Pulley down and larger injectors.
73 Camaro, 6.0 LS, Billet S485, E85, 4L80E.
03-15-2014, 10:25 AM | #3 | |
10.11 @ 136.32
Drives: Black & Yellow 2SS/RS LPE LS7 427 Join Date: Mar 2010
Bryan
03-15-2014, 10:34 AM | #4 |
Drives: Silver 2010 SS Camaro Join Date: Jul 2009
You will for sure need a cam and smaller pulley. Don't forget about fuel or you won't last long. I would go ID850's and dual pumps.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
03-15-2014, 10:36 AM | #5 |
Drives: 2017 ZL1 A10 Join Date: Aug 2009
Experets will chime in but this is from my experience.
Rear OD Cog so you won't run in to slippage issues. Cam & heads would be great. ZL1 pump with BAP may be good but to be safe get a dual pump setup + injectors off course . Don't forget the heat soak issue either with SuperChiller or Meth. Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir Glassskinz rear window valance . 2012 ZL1 A6 (SOLD) Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC. Alky Control, FIICHILLER. |
03-16-2014, 06:19 AM | #6 |
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
Comp Cam w/BTR dual springs, OD rear cogs, 3.6" pulley and ADM's FPCM for your ZL1 pump. Depending on the dyno and what type of fuel you can get octane wise, you will be there.
Find a tuner that knows how to really tune and have them set the cam profile. Sent from my iPhone using Tapatalk
03-16-2014, 10:28 AM | #7 |
Drives: Maggie blown LS3 vette Join Date: Aug 2009
To hit 650 wheel, you need a blower cam and overdrive rear pulleys. Your 3.8" front pulley should do fine. You don't have to go apeshit with the cam. Something like this http://www.lingenfelter.com/mm5/merc...1#.UyXBr7lOU5s would be great for a camshaft. All this is assuming you have LT headers and a good exhaust. Also assuming you have proper injectors and the fueling system to feed them.
03-16-2014, 02:27 PM | #8 |
Thanks guys
Any more ideas? |
03-16-2014, 03:41 PM | #9 |
Guest
I reached 650 rwhp with an auto with
Maggie OD cog, 3.4 front (12psi) Night Fury cam, LPE twin, 850 ID's, LT's |
03-16-2014, 04:40 PM | #10 |
03-16-2014, 05:40 PM | #11 |
Drives: 2011 SLP ZL-585, 13' Silverado Join Date: Apr 2012
About the same setup. OD cogs and 3.6pulley, kooks LT, Rotofab intake, ID850, ZL1 fuel pump and a great tune and youll be @ 650 RWH. That's my setup and than the torque pretty much systematically took out clutch, driveline, axles ect. Plan on investing your cam $$$ into drivetrain!
03-17-2014, 04:38 PM | #12 |
03-18-2014, 08:50 AM | #13 |
Drives: 2010 Join Date: Jul 2009
Make sure you upgrade the axles - or the entire rear end.
Driveshaft probably isn't too far out as well. extra power will break the stock CV joints on the axles. |
03-18-2014, 09:34 AM | #14 | |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
-John S.
