04-15-2014, 08:06 AM | #1 |
Drives: 2010 camaro ss ( LS3 ) Join Date: Apr 2011
Push rods length for GT9 blower cam?
Hey guys!
How's everyone? I'm going to install GT9 blower cam What's the right length for the push rods with this cam? According to COMP's customer service, I need a longer push rods than the stock 7.400" in my LS3 Thank you |
04-15-2014, 09:54 AM | #2 |
Drives: 2013 1SS Join Date: Dec 2012
Only way to tell for sure is to buy a pushrod length checker.
04-15-2014, 12:09 PM | #3 |
04-15-2014, 12:12 PM | #4 | |
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
EDIT: I re-read your post. If Comp is telling you that different length pushrods are needed, then the base circle on the cam must be different. You would be wise to listen to them.
Bye bye, Bumblebee!
04-15-2014, 12:19 PM | #5 | |
04-15-2014, 02:35 PM | #6 |
Drives: G8 Join Date: Feb 2013
If you knew the base circle of the cam, then we could tell you what you'll need.
04-16-2014, 10:56 AM | #7 |
04-16-2014, 02:24 PM | #8 |
What Diesel is trying to tell you is you have to measure the cam with dial calipers or a micrometer. You want to measure to the smallest number you come up with while rotating the cam to find the smallest point.(don't bother with the nose of the cam) For instance my stock cam was 1.503 and my replacement cam was 1 .430. It has a smaller base circle. This is what you need to figure out. This should get you in the ball park, but you need to properly measure with a pushrod length checker at 0 lash. Also verify by the number of turns on the rocker bolt from 0 lash to torqued at 22 ftlbs. should be in the 1 1/2 turn range. Search around there are plenty of threads on this. Take your time and measure twice.
04-16-2014, 02:28 PM | #9 | |
I will! Thanks |
