05-25-2014, 05:24 PM | #1 |
Drives: 2010 camaro ss ( LS3 ) Join Date: Apr 2011
LS7 camshaft for l99, what should I replace?
Hey guys!
How's everybody? So, a friend of mine wants to install an LS7 camshaft to his L99 Camaro I know this cam doesn't make a lot of power, but that what he wants LOL I knew that he should install a DOD delete + LS7 valve springs + 3 bolt cam conversion + heavy duty chain + high volume oil pump. Did I mention something that he doesn't need? or did I forget anything? Please let me know guys, thanks |
05-25-2014, 08:33 PM | #2 |
Drives: 2013 SS Join Date: May 2013
Smh if he goes with it. Be a ton cheaper to get a small vvt cam.
05-25-2014, 09:19 PM | #3 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Ryan (Rhino79) can tell you everything you'll need and wrap it all up in a nice kit. He's a firm believer in not changing everything under the hood so you'll save some money too.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
05-25-2014, 10:27 PM | #4 |
Drives: 13' 1LE Join Date: Apr 2012
Id put a LS9 cam. Its better than the LS7 for what hes doin. Id get a small custom cam with low lift at least.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
06-16-2014, 10:22 PM | #5 |
Drives: 2010 ss/rs Join Date: Jun 2013
any idea what length pushrods are needed?
rotofab cai
ported throttle body sp headers with cats loud mouth axle back no mufflers tuned by steve williams 6l80etuning.com bmr split springs cam motion custom camshaft btr 660 spring kit maggie 2300 id850 injectors livernois fuel pump |
06-17-2014, 08:42 AM | #6 |
Drives: C6 Corvette Join Date: Sep 2013
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
