01-10-2016, 04:29 PM | #1 |
Drives: 2010 camaro ss ( LS3 ) Join Date: Apr 2011
Stock differential power limit?
Hey guys!
What's up? I wonder if the stock differential will hold 800+ rwhp if I upgrade the driveshaft and axles, I don't drag race, all of my races start from 40-75 mile/hr, I have a manual transmission by the way, any thoughts? |
01-10-2016, 05:47 PM | #2 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
You hook, you break.
With what you're saying, you "should" be okay.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
01-11-2016, 02:18 PM | #3 |
We have cars making 950 RWHP on stock Rear Diffs. If you aren't launching on slicks or something, I would expect you'd be okay.
All the best, Jared Royce 888.308.6007 |
01-11-2016, 05:34 PM | #4 |
Drives: own more cars than i can list Join Date: Nov 2010
I agree with them, as long as there is no hard traction in the beginning you should be fine.
01-11-2016, 07:01 PM | #5 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
If the diff does break it's usually the posi which is why switched to a truetrac. I've heard people doing fine with these on auto cars even with slicks. Once I move on or it breaks I'll swap out to the moser solid 9 inch drag kit.
01-11-2016, 07:03 PM | #6 |
Svt lol
Another option for you (if something does happen) zl1 diff is always an upgrade and if you shop around you can pick them up cheaper than a 9 inch swap (no offense vendors).
01-12-2016, 07:20 AM | #7 |
He is right, the ZL1 diff is a good option, gear selection is not as wide as say the other options but for under 1000Hp it cant be beat (may want to use aftermarket axles and Driveshaft on it though)
01-12-2016, 10:43 AM | #8 |
Drives: 2010 camaro Join Date: Jan 2016
In my 2010, I went through the stock diff, a 3.91 from RPM, and another GM ZL1 3.91. I abandoned all 3 because the howling got so bad. Never broke anything on a 520 rwhp manual. Switched to 9" and that kept the gears in shape longer. A dozen passes a week on a prepped track will test your sh¡t
