Old 09-04-2014, 01:55 PM   #1
Bevan175
Drives: 2010 2SS RS Red Manual
current 18" V6 Rims on 2010 2SS RS Camaro
Hello Group,
I made the jump and bought a low mileage 2010 Red 2SS RS manual trans. The car will see some winter driving in Canada. I wanted to confirm with the group if the OEM 18" x7.5" wheels from the V6 Camaro's will fit and work with the larger Brembo braking system. I am OK with all season tires.
Thanks
Bevan175 is offline   Reply With Quote
Old 09-04-2014, 02:06 PM   #2
Scott 78
Scott 78's Avatar
Drives: 2014 SIM SS 6M
I need to know this as well. I keep seeing conflicting answers.
Scott 78 is offline   Reply With Quote
Old 09-04-2014, 02:38 PM   #3
punkindave
The Great Punkin
punkindave's Avatar
Drives: 2013 2SS M6
If you've got the roller skates sticking up on the front brake pads then NO!
No roller skates and I guess it's possible they'd work.
Who opened up a fresh box of idiots without finishing the old box, now they're everywhere!!
Tesla > Edison
punkindave is offline   Reply With Quote
Old 09-04-2014, 02:44 PM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
No, they won't fit.....Sorry!
Old 09-04-2014, 02:48 PM   #5
95birdible
95birdible's Avatar
Drives: 2012 1SS Camaro Convertible
But you can run the 20" that are on the front on the rear to have the same size all the way around. I am thinking of doing this on my 2012 1SS as I would like to be able to rotate the tires and not have the treat almost wore off in less than 20K on it. I do not lay rubber, and do not corner hard. These P zero's just suck for tires in Minnesota
2012 1SS Crystal Red Convertible
"Cherry Bomb"
Winner of the #NameThatCamaro Spring Special Edition
"Green Flash"
95birdible is offline   Reply With Quote
Old 09-04-2014, 02:50 PM   #6
paul44
paul44's Avatar
Drives: 2010 2SS/RS
I bought the v6 18" rims from a friend to install on my 2010 SS. The rims do touch the brembos and they don't fit. The rims I bought were taken from a 2010 1LT non-RS.
You can get some wheel spacers to clear the Brembos, although everyone would just recommend to get new rims with the correct offset.
Personally, I'm getting the spacers hoping to give the car a better stance on 20" and 18".
My build thread:
Evilbee
paul44 is offline   Reply With Quote
Old 09-04-2014, 08:56 PM   #7
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '20 Corvette Stingray
Originally Posted by Bevan175 View Post
Hello Group,
Thanks
NO they will not fit.
OR you could put a set of REARS on the front and run 20 x 9's on all 4 corners, there are a ton of us doing exactly that......I have been for nearly 25k miles.
Old 09-06-2014, 09:09 PM   #8
Bevan175
Can you share more about the "roller skates"?
I did notice that the calipers had what look like wheel weights on them
