11-18-2014, 12:39 PM | #1 |
Drives: 2010 2SS Join Date: Sep 2012
front end makes soft woosh sound when going over bumps.
Installed bmr sway bar end links and the two bushings from the total pro kit as well as steering bushing. Car makes a soft woosh/low dull squeak/thumpy kinda sound when going over bumps at slow speeds. Any ideas? Seems to drive fine. Thanks.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
