01-07-2015, 12:26 PM | #1 |
Drives: 2014 2ls Join Date: Nov 2014
Looking for a DIY Thread
I may be searching the wrong terms or not looking in the right place. I am wanting to paint my steering wheel trim, auto trim bezel, speedometer bezel, and shifter bezel. Is there a DIY thread for this stuff or does anyone have any experience doing this? I just want it all to be black. Dont think it would be that hard to do. But Id like some info/tips on how to get this done. Thanks guys
K&N Typhoon Cold Air Intake/SLP Loudmouth 2 axle back/Touren TR60 Series Rims/Elite Catch Can/Vitesse Throttle Controller/Eibach 1" Drop Springs/GM GFX Splitter/Gen5DIY Fog Lights/4 Pack Gauge Cluster
01-07-2015, 12:40 PM | #2 |
Drives: 2014 2SS RS Coupe Join Date: Aug 2013
Plastidippppp!!!!
01-07-2015, 01:05 PM | #3 |
01-07-2015, 01:09 PM | #4 |
Drives: 2013 AGM 1SS Join Date: Oct 2012
* remove trim (get a set of trim tools at Sears or Autozone or whatever auto parts store you use)
* choose paint or plastidip (it doesn't really matter, depending on if you want it permanent.) * Prep pieces of trim (make sure they're clean, no oils or residue from interior polish or the like, plastic promoter/primer or extremely light, high-grit sanding - only do this with promoter or sanding if you're painting) * paint the trim evenly with multiple coats, allowing the coats to dry properly between each one. * wet-sand if needed, or maybe clear coat (sealer or gloss coat for plastidip) Not extremely difficult to remove trim and re-install... hardest part is the prep and painting process... take your time, don't rush it and pay close attention to details... do that, and you end up with good quality and finish....
01-07-2015, 01:14 PM | #5 |
Thanks for the input pitboss
01-07-2015, 01:43 PM | #6 |
No problem... When you're done, post up some pics!
01-07-2015, 01:57 PM | #7 |
team chicklet camaro
...or, if you have the cash, and don't want the hassle;
http://www.rpidesigns.com/shop/categ...page=3&sortby= Professional, and you still have your stock stuff for the next guy...if you care about that.
01-07-2015, 02:17 PM | #8 | |
01-07-2015, 02:27 PM | #9 |
Indeed. Still have your stock stuff that way, too.
01-07-2015, 02:33 PM | #10 |
anyone know how to remove the two center a/c vents? i saw a thread on here and a guy had his hyrdodipped i think. cant find the thread now.
01-07-2015, 02:42 PM | #11 | |
http://www.camaro5.com/forums/showthread.php?t=65282 http://www.camaro5.com/forums/showthread.php?t=124391 A/C bezel http://www.camaro5.com/forums/showthread.php?t=244655 Gauge bezel http://www.camaro5.com/forums/showth...ing+wheel+trim Steering wheel http://www.camaro5.com/forums/showth...ing+wheel+trim Look around in the DIY section as well as the Interior section. There's plenty of reading in there for your needs.
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap| Built by J-Rod. |
01-07-2015, 03:02 PM | #12 |
perfect thanks!
01-09-2015, 09:17 AM | #13 |
Is there a more recent DIY thread for removing the bezel around the speedometer and gauges? The one I found doesn't have pics anymore.
01-09-2015, 10:01 AM | #14 |
NVM I'm just a dumb***
