03-12-2013, 02:52 PM | #1 |
2013 Camaro V-6 Engine Ticking Noise?
I have a 2013 Camaro V-6 that developed an engine "ticking" noise at 200 miles. It was not there prior to 200 miles. I took it to the Chevrolet Dealer in Sarasota and they said it's the fuel injectors and it's normal. Does anyone else have this same situation? Tom Dietrich wtdiet1944@yahoo.com
03-12-2013, 02:57 PM | #2 |
Drives: 2010 LS 6M Join Date: Jan 2013
Welcome to the fam. I have a 2010 that has ticking and sometimes a chirping sound. These cars have a high pressure direct injection system with multiple fuel pumps and injectors. In order to get the fuel pressure needed the injectors are a bit chatty. Not saying your noise is normal but these engines are known for a little noise. Most likely if it was something bad you get get a check engine light or poor drivability.
03-12-2013, 03:02 PM | #3 |
There is no engine check light on. You only hear it at idle with a warm engine. Dealer said it's normal and not to worry about it, so I guess I won't.
03-12-2013, 03:16 PM | #4 |
Trentin24
I've heard it on my 2010. Was concerned at first. But I've had no problems and it seems to be normal. Is it where you can hear it like every 1-3 seconds? And its always there right? If you rev the engine up it stops. And when it idles back down you can hear it again? Sound about right?
03-12-2013, 03:20 PM | #5 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
The DI fuel injectors make a lot of noise
03-12-2013, 03:58 PM | #6 | |
Let's go Rangers!
03-12-2013, 04:23 PM | #7 | |
Drives: 2011 Chevy Camaro 2LT RS SIM Join Date: Jul 2012
Same Problem
03-12-2013, 04:41 PM | #8 |
Drives: 2010 V6 | M6 Join Date: Feb 2010
Almost have 50k miles on my 2010 with the same ticking noise.
BBK 304 LT headers w/ coating | CAI Inc Intake w/ scoop | VMax Ice-olator | MRT v2 | Elite catch can | Trifecta Tune | Eagle halos | 20" Textured Black Forgestar F14s
- They call it the black panther. 2010 Camaro LLT (sold) 2008 Yamaha WR250X 2011 Nissan Armada 4WD Platinum |
03-12-2013, 04:47 PM | #9 |
Drives: 2010 camaro transformers edition Join Date: Dec 2012
i have a 2010 and you can set a watch by it, how ever in drive throughs its a loud tick and in neutral i rev it and it does not go away it chatters and goes to a really fast tick. my dealer said its normal but im going back on mondayand be there whe the guy looks at it.
SSGT USAF
03-13-2013, 05:45 AM | #10 |
V-6 Ticking Noise
The V-6 ticking noise on my 2013 Camaro is only at idle with a hot engine. If you rev the engine you do not hear it. On a Cold engine you do not hear it. When driving you do not hear it. Dealer said it's the High Pressure Fuel Injectors and it's normal. They said it's nothing to worry about. Thanks for all the responses.
03-14-2013, 08:20 AM | #11 | |
Don't Sleep on My V6
Like said before it's normal for these engine to have a loud tick as it's the injectors clicking away. Nothing to worry about, the Caddy's with the V6's do it also. If you don't hear it is when you should worry. But normal for those not used to hearing it.
If you go to this link it will show all the GM High Feature Engines that would also make the ticking sound. http://en.wikipedia.org/wiki/GM_High_Feature_engine Also here is a bulletin from before the Camaro came out of other cars with this sound. Quote:
02-19-2015, 09:54 AM | #12 |
well im new to Camaro5 and this answered my earlier posts haha
05-11-2017, 12:13 AM | #13 |
Drives: 2011 Camaro RS Join Date: Jan 2017
I have the same problem, I played close attention and it sounds like it comes from the right side of the engine bay, any one else notice that?
05-11-2017, 02:42 AM | #14 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
this problem is also noted in other GM engines that are DI,it doesnt affect driveability .
