12-11-2015, 12:55 AM | #1 |
Drives: Camaro ZL1 A6 Join Date: Jul 2015
how much beating can my tranny get before it goes boom?
hey guys,
so i just took my ZL1 in for an upgrade and i'm supposed to hit around 640whp/660wtq. should i be worried about my transmission? edit: automatic transmission |
12-11-2015, 01:33 AM | #2 |
Drives: 2014 Camaro ZL1 Join Date: Dec 2014
you shouldnt worry on the trans as much as the pistons ...
Lingenfelter 630Hp Package , Afco Heatexchanger , Moroso Catchcan , D3 Tank , Siemens 63Pds/hr Injectors , Custom tune.
12-11-2015, 02:04 AM | #3 |
And how much can they handle before cracking?
12-11-2015, 03:56 AM | #4 |
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jan 2015
Here in Central Florida there are a bunch of people in that 680 hp to 780 hp range, and no one has mentioned transmissions at all. They are 24% stronger than the last generation... and of course the 9.9" rear ends are great too.
12-11-2015, 03:58 AM | #5 |
I cant really confirm how much rwhp exactly , but some say 800~ range . But lets see what others say ..
12-11-2015, 09:44 AM | #6 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
640 is nothing for the trans or the pistons. The only ZL1 owners that I know of having any automatic transmission problems the the guys doing A LOT of drag racing and they are the guys flirting with the 9's. If you don't drag race it and have close to 800 whp then you should be fine.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
12-11-2015, 10:20 AM | #7 |
By drag do you mean like actually going to the strip? Or are the road races considered bad too?
12-11-2015, 10:31 AM | #8 |
I'm one of those guys that have pooched my trans. I have also made a TON of passes at the drag strip, over 700, and I'm currently around 740 whp. The clutches were toast when we took it apart. I replaced mine with a GM rebuilt stock trans but am looking to buy an upgrade kit to beef it up. My car runs high 9s.
12-11-2015, 12:57 PM | #9 | |
Speed Freak
Thanks for commenting mrvenicess, I was thinking about you and Dan.
12-13-2015, 07:24 AM | #10 |
Drives: 2014 ZL1 White Convertible Join Date: Aug 2013
Mrvenicess took me for a ride in his Zl1 when I had gone to get my car tuned at Florida speed and power. Gotta say what fun drive that was; as he was smoke'm down the road I thought to myself, " I wonder how much of a beating and how long his tranny will handle that kind of power" as the launch was incredible, but then I thought if you aren't having fun in it, then you bought the car for no good reason. memories are everything. Not sure you remember sharing your ride with me, but I always will, thanks.
12-14-2015, 06:37 AM | #11 |
Any time my friend!
12-14-2015, 02:30 PM | #12 |
Worry not, my friend. That trans should be good well past that HP mark.
All the best, Jared Royce 888.308.6007 |
12-15-2015, 09:12 AM | #13 | |
Drives: something faster than you Join Date: Aug 2010
Now on a road course is really where you're going to destroy shit. Not saying that he will, but a 20 minute session of high RPM full throttle and constant shifting up and down is going to be a helluva lot more abusive than a bunch 11 second runs at the drag strip. |
12-15-2015, 10:02 AM | #14 | |
Speed Freak
I don't drive any road course where I need first gear on the track and I personally don't hardly use second gear much because these v8's can pull third and put down lap times just as fast as dropping to second in the tight turns. The autos are getting hot on the road racing tracks but as long as owners are changing the fluid regularly no one is reporting problems road racing. 2 drag racers that I know of have had auto transmission problems, one of them answered this post. No road racers that I know have had auto transmission problems other than simple heat. The car kind of shuts itself down when the trans overheats so you quit beating on it. I guess that is why they don't fail road racing. Eventually road racers get bigger coolers and are fine.
Thread Tools | |
