01-29-2024, 06:21 PM | #1 |
Drives: Camaro ZL1 Join Date: Apr 2023
Where Do These Plastic Pieces Go?
I've had these things laying in the garage for over 2 years now. They were in the trunk when I picked up my '22 ZL1. For the life of me I can't line up any holes under the front of the car where they might go.
Pix will help greatly.. |
01-29-2024, 06:44 PM | #2 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
They go under the front bumper mounted to the black plastic shielding. Your dealer should have installed them during PDI.
01-29-2024, 06:45 PM | #3 |
Drives: 2021 ZL1 1LE with PDR Join Date: Oct 2022
They look like are part of the brake cooling ductwork. The rounded ones are the tire deflector, I forget what the others are.
01-29-2024, 07:35 PM | #4 |
Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
They attach in front of the front wheels on each side, with the rubber/plastic strip, going across the front of each front corner. They basically funnel air on to the tire.
01-29-2024, 07:39 PM | #5 |
Drives: 2024 ZL1 M6, 1969 Cessna Skylane Join Date: Jun 2018
I remember someone saying two of the pieces are just for the track. Not sure if that's true or not or why.
01-29-2024, 08:35 PM | #6 |
What about the 2 flat straight pieces?
01-29-2024, 08:53 PM | #7 |
01-29-2024, 09:06 PM | #8 |
Thank you
01-30-2024, 02:03 AM | #9 |
Drives: '24 ZL1 A10, '70 Olds 442 W-30 Join Date: Sep 2023
01-30-2024, 06:18 AM | #10 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Mine were installed by the dealer.
01-30-2024, 07:49 AM | #11 |
My dealer left the two flat pieces off too. I installed them since they offer some protection for the underside of the front bumper.
01-30-2024, 08:06 AM | #12 |
Nightmare
Drives: Your mom crazy in bed Join Date: Mar 2011
Usually, these are installed by the dealer after the car is taken delivery of as they will often scrape being unloaded if installed due to the incline on those trailers. That's something to keep in mind if the car has to be trailered or towed moving forward. This is also why many cars don't get the spring blocks (orange blocks) removed because the car sits higher in front.
I do recommend installing them however if you are planning to track/race the car for any reason. It does help with the aero on keeping the car planted. It's not a must have item but it's a very painless install if you do have to do it.
01-30-2024, 02:35 PM | #13 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
here's the sheet that should have come with them
01-30-2024, 07:17 PM | #14 |
Drives: Sharkskin Metallic ZL1 Join Date: Mar 2023
I really like this forum. I asked this exact same question last year in a Facebook group and got "RTFM' for an answer. Go figure. Anyway, this is a great place to learn.
