Old 01-11-2013, 04:13 PM   #1
TRABlackCamaroSS
TRABlackCamaroSS's Avatar
Drives: '10 Blk Camaro SS/'08 Blk Silverado
RK sideskirts
just bought the RK sideskirts(ground effects) for my CamaroSS. The instructions are vague & only tell how to prep the part for paint but nothing about installation.
my question is this....do you remove the stock OEm part from under the door or do you just overlay the piece on the existing stock body part?
I really can't move forward on this install until I have a correct answer...
Anyone installed this particular sideskirt? any info would be helpful
Thanks!
TRABlackCamaroSS is offline   Reply With Quote
Old 01-11-2013, 04:17 PM   #2
Asian Zero
Asian Zero's Avatar
Drives: 2010 IBM Camaro 1LT RS
does it have tabs or anythign where you would attach a screw? or is there like 3m tape all along it? if theres 3m im assuming its overlay. if not you probably have to take off the old rocker.
Asian Zero is offline   Reply With Quote
Old 01-11-2013, 05:25 PM   #3
LnLSS
Mid-Florida Camaro Club
LnLSS's Avatar
Drives: 2015 Red Hot ZL1
Old rockers will need to come off either way. Be careful after paint if it is 3m tape as the baking process tends to dry out the tape.
LnLSS is offline   Reply With Quote
