02-23-2014, 11:20 PM | #1 |
Drives: 2010 2SS/RS M6 Join Date: Aug 2013
V6 Brake Swap Help
Doing a v6 brake swap on the rear of my 2010 ss. Am I missing anything?
I have ordered: V6 calipers V6 backing plates V6 rotors I plan to order stainless lines, do I need brake lines designed for the v6 cars or for a SS? Do I need anything else to keep the e-brake functional? Thanks!
2010 2SS/RS
02-24-2014, 02:22 AM | #2 |
Negative Camber Junkie
Drives: 2010 1SS LS3/6MN ABM 1 of 23 Join Date: May 2009
Why would you need SS lines?
Give Rodney or Matt @ FSP a call in the morning. They have done a ton of these. T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same. Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different. I can't wait for my next Track fix. DA HAWKS OWN DA CUP!!!!! |
02-24-2014, 06:45 AM | #3 |
Just upgrading to slotted rotors and stainless lines front and rear while I swap the rear brakes. Wasn't sure if I needed to buy them for the v6 cars SS car.
2010 2SS/RS
02-24-2014, 07:45 AM | #4 |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
I know on the v6 if you want to upgrade to the brembos you need the calipers, rotors and brake lines. Not 100% sure if you would need the v6 lines when going to the v6 brakes from the brembos but i would think so.
02-24-2014, 05:35 PM | #5 |
OK, wait a minute. If you are going to the V6 Brakes in the rear I am guessing you are doing it to fit smaller diameter rims so you can fit larger tires for drag racing, right? I mean there isn't any other reason to do it. So if that is the case why are you spending money on slotted rotors and stainless steel lines? People only need those if the needs to keep their pads/rotors cooler and lines from flexing when they Autox/HPDE. You would save some money by just using stock rotors/lines that you could put towards rims/tires which are expensive enough.
T.
02-24-2014, 06:21 PM | #6 |
The SS and V6 calipers do require different lines. I do agree with TBone though; the money spent on upgraded lines and rotors could go toward other things.
Best regards, Tyler 888-308-6007 |
02-24-2014, 10:33 PM | #7 |
Good point fellas. Even though the car is getting a drag wheels, it'll still get driven regurally and is mainly a street car, so that was my reason for wanting to upgrade.
I picked up a set of lightly used v6 rotors which should be here Friday. I'll see how it does with the stock parts, and upgrade later if need be. Thanks!!
2010 2SS/RS
02-25-2014, 12:15 AM | #8 |
Sure. You should be fine with them as long as you remember that you now have V6 brakes. No amount of slotting or drilling to the rotors will make up for the SS calipers. But hey, the V6 guys seem to do OK with them so you should be alright.
Besides, more room for smaller rims, bigger tires, right? Like 'dis... Photo stolen from Ian Schexnider Photography facebook page. T.
02-26-2014, 12:33 PM | #9 | |
Thanks bud!
2010 2SS/RS
10-03-2021, 09:49 AM | #10 |
Drag and Drive is Life
Drives: 2010 Camaro 2SS RS A6 LS3 Whipple Join Date: Aug 2021
Great info glad i found the post i was wondering.. Thanks guys
My build link... https://www.camaro5.com/forums/showt...4#post11077544
2010 2SS/RS/ Mods, Whipple, 1000cc injector, 102MM TB, Innovation West 10% OD pulley set up 8 rib, AGP twin 450 fuel system w flex on E85, CAI K&N, LT with OR Cats aka no catalytic converters, Coils and wires, 3" exhaust with mufflers, Oil catch can, 2015 ZL1 9.9 3.23 ratio, BMR upper Lower control arms, 15"conversion, BMR Anti Roll Bar 315/60/15 ET street slicks 1972 El Camino SS 565BBC 950HP, All TRZ suspension |
10-03-2021, 09:56 AM | #11 |
10-03-2021, 01:36 PM | #12 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
My Car, so you could swap the calipers, brake lines, rotors and new pads
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
10-03-2021, 03:35 PM | #13 |
Drives: camaro Join Date: Oct 2020
Any idea how much weight you saved vs brembos with the ebay brakes? Did you get lines also?
10-14-2021, 08:58 PM | #14 |
I’ll say from box weight 51lb I’ll get better numbers when I pull mine off! Box was 53lb
