#Camaro6
BeckyD @ James Martin Chevy
Old 07-22-2017, 05:04 AM   #1
Bunksy
Drives: Gen 6 ZL1 White
New ZL1 Issues
I've had my ZL1 coming up to two months and the list of issues is getting longer! Nothing is critical but all stuff that I need sorting out:
1. Rear bumper paint cracking at corner (common issue)
2. Air conditioned seats don't always work properly
3. Trunk release is occasionally works
4. Front screen fogs up in slow or standstill traffic (common issue #17-NA-201)
5. FM radio reception is terrible
6. Knocking from the front over speed bumps - loose sway bar PIC6276
7. Aggressive shift from 4th to 5th when driving hard 16NA019
Can anyone comment on the above? Would be good to have some ammo before taking it into Chevrolet.
Thanks,
Bunksy.
Bunksy is offline   Reply With Quote
Old 07-22-2017, 05:06 AM   #2
crunch527
Drives: Big Brown
#6 sounds like the sway bar needs to be tightened...there is a TSB on the issue...
The rest???
crunch527 is offline   Reply With Quote
Old 07-22-2017, 05:32 AM   #3
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
#2 - the AC has to be on in order for the seat cooling to work.
Gunkk is offline   Reply With Quote
Old 07-22-2017, 05:35 AM   #4
Bunksy
I never switch the AC off. Living in Dubai there is little choice!
Old 07-22-2017, 05:51 AM   #5
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
These are not A/C seats. They are ventilated.
Wondering about that TSB with front window fogging up. Is there a fix?
Old 07-22-2017, 06:28 AM   #6
Bunksy
TSB for the front window is #17-NA-201.
Hmmm only ventilated seats? In theory whatever temperature air comes out of the dash vents should also come out of the seats!
Old 07-22-2017, 06:44 AM   #7
HDRDTD
I believe the ventilated seats simply are driven by a fan, and not connected to the interiors cooling system in any way.
Old 07-22-2017, 06:50 AM   #8
vy427
Drives: '21 ZL1 A10 Convertible
My C7 Corvette has ventilated seats. They work much better when the floor vents are run along with the dash vents. Cold air directed right on the floor can better feed the seat fan. Only negative is the dash vent pressure isn't as strong when running the floor vent too.
vy427 is offline   Reply With Quote
Old 07-22-2017, 07:42 AM   #9
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
That is not the case. All they do is vent the heat out of the seats. There is no control of the temperature of them.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 07-22-2017, 08:19 AM   #10
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
ventilated seats are "fan only"
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 07-22-2017, 09:36 AM   #11
CarFlow1
Drives: 2017 ZL1 A10 (Summit White)
#3 yes, I'll be taking this into the dealer to fix that trunk. Sometimes the trunk doesn't open even though the computer thinks that it is. Which requires me to go through the car, pull down the back seat and pull/lift up my trunk from the inside of the car.
CarFlow1 is offline   Reply With Quote
Old 07-22-2017, 09:44 AM   #12
Artos
Artos's Avatar
Drives: A10 LT4
I'll need to try that...does the recycle air still stay on?? I think every vehicle I've had looses the max / recycled AC when using the floor as it's a heater function??
Proper AC is mighty important right now...I do wish the seats had full blown AC. I'll likely never use the heated seats / wheel.
Artos is offline   Reply With Quote
Old 07-22-2017, 09:51 AM   #13
utsteve98
Drives: 2018 ZL1 1LE, 2017 Ford Raptor
Not sure why you're having an issue on the A/C seats. Mine get cold fast. And I don't believe it's accurate to say these seats only take out the hot air. They are paired in conjunction with the A/C cause there is no way mine blows that cold when the temperature outside is 100 degrees. They should be working in conjunction with your A/C and ventilate the cold air into them.
utsteve98 is offline   Reply With Quote
Old 07-22-2017, 12:33 PM   #14
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
Thanks,
Bunksy.
What exactly do you mean by front screen?
speedraider is offline   Reply With Quote
